Identify this part/its purpose
What exactly does this thing pictured do? Whats it for?
The One And Only !!!
Re: Identify this part/its purpose
That's your cruise control transducer, Without it your cruise won't function.
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
Squarebody Aficionado
yeah its your speedo, on cable goes from your cluster to that piece, and that piece to your tranny. if you remove it you might have to get a new speedo cable
haha, ford guys...
does the cruz controll mantain costant speed??
(if its set at 55.. will it go 55 up hill?) |
A properly functioning one will.
Oscar '72 Shortbed Fleetside '95 Jimmy 4X4 '69 GMC Custom Camper |
So is it safe to assume the same if you go down hill?, provided you don't hit the brakes first and activate the vacuum disengagement.
51 Chevy 3100 Deluxe Cab(SOLD) ![]() 65 **stang 6cyl 70 C10 Long Bed Fleetside(1st truck,thanks Dad![SOLD]) 72 C10 Short Bed Fleetside 73 Blazer 2WD Catalina Blue White Top(Needs Love) 73 Blazer 2WD Work in progress LT1/4L60E 83 Grand National (SOLD) 94 Blazer K1500 Silverado (SOLD) 96 Impala SS All original (NEXT IN LINE 2 B SOLD) 99 Tahoe 2DR, 2WD ![]() |
#9 | |
Old Heap Driver
BTW...I added a cruise unit from Dakota Digital on my truck, LOVE it, especially on long trips.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
Don't Crush em Restore em
That is an after market, I believe, it might work if you hook up the missing vacumm line that is off in the picture. There should be some parts on the carb linkage too, it looks very similar to the one I took off my truck after I bought it. Mine even had a sensor on the drive shaft.
TexasJeff 2009 Silver with Linen Interior Cadillac DTS 1990 Red with White Top and Interior Ford Mustang GT convertible 1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually ![]() ![]() ![]() ![]() ![]() ![]() |
Any idea of what that set-up cost?
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
#12 | |
1979 C10 Silverado 1998 Camry 5spd 2005 Harley ElectraGlide Last edited by C10Silverado79; 03-26-2010 at 03:48 PM. |
#13 |
Sorry Jeff, but that is factory. i highly doubt it will work even with the vaccum line hooked up. they are known to go bad and not hold a steady mph. there is a rubber diaphram inside that goes bad over time.
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list ![]() |
#14 |
Opps, sorry for the misdirection, mine looked similar but was for sure after market.
TexasJeff 2009 Silver with Linen Interior Cadillac DTS 1990 Red with White Top and Interior Ford Mustang GT convertible 1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually ![]() ![]() ![]() ![]() ![]() ![]() Last edited by TexasJeff; 03-26-2010 at 12:35 PM. |
#15 |
Is it worth trying to fix the factory CC? Mine tries to work but cannot hold the mph. It slowly decels.
1979 C10 Silverado 1998 Camry 5spd 2005 Harley ElectraGlide |
#16 |
i wouldnt... i replaced mine twice. even when it was working it left alot to be desired. if i was to do it again i'd just use the dakota one like Bryan(S10Fan).
#17 |
yea i chunked mine in the rebuild
2014 LTZ Z71 Silverado 82 C15 LQ4/4L80E Conversion 78 Suburban build (SOLD) 83 4x4 Suburban(SOLD) 82 C15 (my first truck) |
