03-25-2010, 10:52 PM | #1 |
Replacing body mounts
I was installing new body mounts today and have a couple big washers that I was wondering if they go between the bushing and body on the rear. It was a counterparts replaceable body mouunt kit. Maybe someone else as used one. On the rear I have a nut, washer, cone bushing, then frame then upper bushing then body. I have the bolt with sleeve going through it. I was thinking the other washer I have goes between the body mount and body.
anyone know? The fronts seem to be together correct. There was a square piece of metal between the bushing and the body that I left in there for the new mounts. |
03-25-2010, 11:03 PM | #2 |
Re: Replacing body mounts
I need to know too.
03-25-2010, 11:07 PM | #3 |
"I'll Procrastinate Tomorrow" quote by LEEVON 71 K10 long fleet (sons truck) new 370hp 355, sm465 np205, 3.73's 33's 70 K20 long fleet 98 G3500 work van |
03-25-2010, 11:16 PM | #4 |
It helps a bit, but I am wondering with the aftermarket ones I bought if they are going to be installed the same way roughly....
03-25-2010, 11:21 PM | #5 |
03-26-2010, 10:07 PM | #6 |
Never Ending Projects
When I tore apart my '68, both the front and rear cab bushings had washer top and bottom, so to answer your question, yes mine had a washer between the cab and the top bushing.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
01-11-2012, 03:00 AM | #7 |
Thanks for the diagrams to properly replace the bushings. My problem is getting the nuts off the body bolts. I finally got the nut off the front mount after taking out the radiator. How do I gain access to the top of the bolt on the driver side middle mount since it simply spins with the nut? Got any tips to make this task any easier?
