top loader & cab mount question
I have a 62 k 20 how do I remove the shifter? Its a top loader. The tranny looks to have a pin-(s) holding the shifter in place (Its worn out and has a lot of slop). Im getting ready to put a new cab on the truck soon but need to remove the shifter. Also Im rebuilding the cabmounts there the same as a c 10 not the c-k 20-30 type, why I don't know? But it works out good ,I have all new rubber mounts. I need to know the hole diameter. The originals rotted away on the top . Thanks
Re: top loader & cab mount question
Can't help you with the cab mounting issues, but I can tell you how to remove the shifter. Remove the rubber boot from the floor, you can just slide it up the shift handle toward the shift knob. Where the shifter comes out of the trans the shift shaft should be covered with a tin,(sheetmetal) ball shaped cover about 2" in diameter. Firmly grasp the shifter handle with one hand and the tin ball cover with the other hand. Push straight down on both and try to turn them either right or left to about the 10:00 or 2:00 o'clock position. This should "unlock" the shifter so you can pull it straight up and out of the trans. Hope this works for you.
rwgregory 67 GMC 2500 ,2w/d wide box 305 V-6, 4-speed |
