Old 03-26-2010, 02:14 PM   #1
sixD8
sixD8's Avatar
when checking your fuel level with a DOWEL ROD...
In a behind the seat tank.....how many inches is equal to a gallon? I'm looking for a fuel sending unit at the moment and am trying to figure out my fuel level. I'm sure some of you guys have been there.
sixD8 is offline   Reply With Quote
Old 03-26-2010, 02:32 PM   #2
DT1
DT1's Avatar
Re: when checking your fuel level with a DOWEL ROD...
I've been there but I use to check it by lighting a match and looking inside.
Seriously, I would fill it up and record the miles driven and gallons used then compare that to the tank capacity.
The shape of the tank might be such that you can't make a linear scale.
DT1 is offline   Reply With Quote
Old 03-26-2010, 02:38 PM   #3
sixD8
sixD8's Avatar
Match...Gas...LOL...I think I will stick with the dowel rod.
Old 03-26-2010, 07:56 PM   #4
JimKshortstep4x4
The tank being the shape that it is will cause a variation in the gallons per inch as measured on a stick. When the tank is below one half, each inch will be close to 1.1 gallons. If the gas is closer to the top each inch will be less than a gallon.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 03-28-2010, 12:36 PM   #5
pritch
pritch's Avatar
Jim
That can't be right-everybody knows that the last half of the tank goes faster than the first half!
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 03-28-2010, 05:39 PM   #6
kevmic28
kevmic28's Avatar
You could always run it out of gas and tap a brass plug in the bottm and top of the tank behind the drivers seat and run some clear fuel tubing between them. Then you will always know how much fuel is left.
1970 GMC truck
1988 Harley 1200 Sportster
kevmic28 is offline   Reply With Quote
