Old 03-26-2010, 05:11 PM   #1
OhOneWS6
OhOneWS6's Avatar
Stock 1/2 ton front coils
Anyone have any stock front coils they took out of a 71 or 72 1/2 ton, small block truck they could measure for me. Pics would be a big help as well. I'm trying to figure out if these are the original stock springs out of my truck. Speculation is they may be 3/4 ton or 73 & ^.
Side by side with ECE 2" drop springs
OhOneWS6 is offline   Reply With Quote
Old 03-26-2010, 05:33 PM   #2
72K20
Slow Old Timer
Re: Stock 1/2 ton front coils
If I remember right, I was told that stock springs measured 13 inches. Those also look a little beefier so maybe your theory is correct.
72K20 is offline   Reply With Quote
Old 03-26-2010, 05:35 PM   #3
dfwright
dfwright's Avatar
My Stock springs measure 14" top to bottom (after removing them from the truck). I have a 72 1/2 Ton, 350/350
Oh, and the stock Delco springs I bought to replace them, measured 13.75" top to bottom.
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 03-26-2010, 07:44 PM   #4
OhOneWS6
OhOneWS6's Avatar
That sounds reasonable close to mine. I could see them being 1/2" different after 40 yrs of settling. Anyone else?
Old 03-26-2010, 08:45 PM   #5
junkman
I just pulled a 72 front end apart today, the ones out of it measure a little shy of 13 3/4
junkman is offline   Reply With Quote
Old 03-26-2010, 09:11 PM   #6
OhOneWS6
OhOneWS6's Avatar
That seems reasonable close as well.
I guess the next step is to measure the diameter of the wire used to make the springs. Anyone got a set of calipers they can check that with?
Keep them coming. I need as much info as I can get. Here is the issue we (ECE and I) are tying to resolve.
http://67-72chevytrucks.com/vboard/s...d.php?t=390476
Old 03-27-2010, 06:39 PM   #7
OhOneWS6
OhOneWS6's Avatar
No one with stock springs and a dial caliper??? Mine measured .776
Old 03-27-2010, 09:42 PM   #8
BOZO
Old School
BOZO's Avatar
My stock 1969 1/2 ton small block front springs measure .778.
#1 Project...69 Chevy swb Fleetside (Dad's truck)
#2...1983 El Camino SS (Choo Choo Custom)
#3...1974 Datsun truck (4.3L V6/4L60E)
#4...1951 Cadillac Limo (1975 Caddy running gear)
#5...1938 Dodge M38 3/4 ton Military truck
#6...1968 Sportster XLCH trail bike
5 GMC & Chevy parts trucks 68 to 72
Last but not least;
My 1978 Harley Davidson Electraglide
(trusted & reliable companion for the last 30 years)
BOZO is offline   Reply With Quote
Old 03-28-2010, 10:15 AM   #9
OhOneWS6
OhOneWS6's Avatar
Thanks BOZO. That is pretty close to mine. It seems my springs are no different than any other 1/2 small block springs as far as the dimensions. I guess they could still have a different rate if the material is a different hardness.
Anyone else got a set of stock 1/2 ton springs laying around? More information is always helpful.
Matt
Old 03-28-2010, 10:49 AM   #10
Trip59
Who needs sleep...
Trip59's Avatar
Mine looked almost exactly the same when I took them out side by side with the 2" drops (if you recall from the other thread). I measured the drop springs before putting them back in, they were 12" exactly. The stocks I don't have a pic of, but they were (cut two coils) just over 13", but that's on a 38 year old Georgia farm/ranch truck with a quarter million miles. spindle center to fender measurement was just over an inch less with the drops installed.
Trip
Trip59 is offline   Reply With Quote
Old 03-29-2010, 04:57 PM   #11
frankdatank01
My springs are 12 7/8 " high. I don't have a set of calipers. The spring diameter is 5 1/2 ".
1970 C10 CST
Frank
frankdatank01 is offline   Reply With Quote
Old 03-29-2010, 05:15 PM   #12
frankdatank01
1970 C10 CST
Frank
Old 03-29-2010, 06:23 PM   #13
1-PU70
1-PU70's Avatar
If you go to NAPA's web site the give the hight and coil thicknes of there springs.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
Old 03-29-2010, 11:11 PM   #14
OhOneWS6
OhOneWS6's Avatar
Thanks Frank.
1-PU I am only concerned with factory original springs. I'm trying to figure out another issue.
