Old 03-26-2010, 07:59 PM   #1
Allens86
Allens86's Avatar
Question about flip kits...
I'm planning on dropping the rear of my 1986 Chevy c10 another 4 inches with a flip kit. I was just curious if you actually needed to cut the frame and add a C notch or if its not needed. I've heard both that you shouldn't need to and also that you would need to. If anyone could help clear this up for me I would very much so appreciate it. Thank you.
-Allen
...............................____
.................________-|___\____
..;.;;.:;:;.,;.|__(O)___|____/_(O)|
1986 Chevy Custom Deluxe
Nothing like a square body
http://67-72chevytrucks.com/gallery/...0&ppuser=45891
Allens86 is offline   Reply With Quote
Old 03-26-2010, 08:10 PM   #2
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: Question about flip kits...
what other method of rear drop do you have
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 03-26-2010, 08:12 PM   #3
Allens86
Allens86's Avatar
Right now i have hangers and shackles.
Old 03-26-2010, 08:18 PM   #4
flamingbig10
6.0 powered square
I flip would give 5" drop at minimum, and would require a small step notch drop shocks, shock extenders and pinon angle would be bad you"ll want drop leafs or removed leafs, or get stock hangers and do a flip kit
Aaron
Old 03-26-2010, 08:21 PM   #5
Allens86
Allens86's Avatar
Well what i was wanting would be just another 4" drop on top of the 4 i already have. So i would need to use a C notch unless i swapped back to the stock hangers?
Old 03-26-2010, 11:36 PM   #6
datguysaL
you could probly wing it.
if you do the flip-kit, and remove the shackles, leave the hangers and cut the bump stop bracket and mount the bump-stop directily to the frame. but either way, you suspension travel will still be short.
datguysaL is offline   Reply With Quote
Old 03-27-2010, 01:17 AM   #7
spinem
haha, ford guys...
stock suspension flipped is ok, get some air shocks if u can afford it to keep em from smackn... if u cant afford the shocks, just go slow over buumps..
now sense u have the shackels... i dont know... most likely not man. do you still have the factory ones? if so, have em handy.. if it looks too tight, replace them /w/ stock shackels...
btw... lmc says a flip will give you 6in of drop... they are damn close.
spinem is offline   Reply With Quote
Old 03-27-2010, 01:38 AM   #8
fiddy9apache
fiddy9apache's Avatar
you will need a c-notch. flip and 2in shackles works great, how you plan on doin the front?
fiddy9apache is offline   Reply With Quote
Old 03-27-2010, 02:17 AM   #9
Allens86
Allens86's Avatar
I was trying not to use a C notch just because I dont want to weaken the frame but i guess i wont have much of a choice.
Fiddy9apache- in the front I already have 3 inch drop coils and im gonna use some spindles to lower it another 3 inches
Old 03-27-2010, 09:51 AM   #10
fiddy9apache
look into drop lower control arms, they keep stock track width so you wont have to worry about rubbing the fender went you turn.
and a c-notch, if dont correctly, will not weaking a frame.
Old 03-28-2010, 03:51 AM   #11
Allens86
Allens86's Avatar
Oh ok thank you. Do you happen to know any places that have the kits to lower the lower control arm?
Old 03-28-2010, 03:56 AM   #12
Allens86
Allens86's Avatar
Also with the c notch would i still be able to tow something?
Old 03-28-2010, 10:33 AM   #13
flamingbig10
6.0 powered square
you'll still be able to tow with c-notch but if you wan't max factory carry loads you'll want to weld it in to be safe and also helper bags
and the lower control arms
http://www.summitracing.com/search/M...&Ns=Price|Desc
Aaron
Old 03-28-2010, 03:02 PM   #14
Allens86
Allens86's Avatar
Would it be a better to buy the upper and lower together? or would it not make too much of a difference?
Old 03-28-2010, 04:19 PM   #15
CenValyCali
Do you have to cut out the bed when adding a little c-notch? Thanks... Now I'll go and introduce myself
CenValyCali is offline   Reply With Quote
Old 03-28-2010, 05:39 PM   #16
nlped
nlped's Avatar
^^^No you won't have to cut the bed to put in a small c-notch. It helps to pull the bed off to put it in, but you don't have too.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 03-28-2010, 08:35 PM   #17
flamingbig10
6.0 powered square
Aaron
Old 03-28-2010, 08:42 PM   #18
fiddy9apache
just buy the lowers, theres no need for uppers unless you want the look.
Old 03-28-2010, 11:51 PM   #19
Allens86
Allens86's Avatar
oh ok well thank you everyone for your help
Old 03-29-2010, 01:35 AM   #20
CenValyCali
Originally Posted by flamingbig10 View Post
Wow that's not much of a notch. It gives you maybe an extra 2 inches? Did you end up cutting off the old mounting bracket for the leafs? In your picture it's still on, so I was just wondering if maybe that was cut off if you would still need the notch. Either way I'm going with a notch. Can you post a link to where you bought your flip kit. Thanks
Old 03-29-2010, 10:33 AM   #21
nlped
nlped's Avatar
The leaf spring perch ("mounting bracket") is actually outboard of the frame and doesn't post any issues.
Carter
Old 03-29-2010, 07:28 PM   #22
flamingbig10
6.0 powered square
http://www.summitracing.com/parts/BEL-6850/
Aaron
Old 03-30-2010, 12:03 AM   #23
nlped
nlped's Avatar
^^^That one is high as Giraffe Pue Nanny!!! Look at this one
http://cgi.ebay.com/ebaymotors/mcgau...item4396817ff9
but I bet if you checked with some of our vendors, they would have a much better price.
Check w/ Porterbuilt , he seems to be a He!! of a guy
Carter
