Old 03-27-2010, 10:58 AM   #1
FOREVER71
FOREVER71's Avatar
wtb carier bearing bracket.
lost my bracket for my carier bearing...i think there is three styles. so if any one has any post pics..my truck is a long bed leaf truck...if that helps.i was going to do a one piece but now i have changed the plan....any help...jeemy
FOREVER71 is offline   Reply With Quote
Old 03-27-2010, 11:15 AM   #2
sharpie1972
Re: wtb carier bearing bracket.
Hi Jeremy, 71 C20 leaf sprung. Sharpie
sharpie1972 is offline   Reply With Quote
Old 03-27-2010, 12:24 PM   #3
FOREVER71
FOREVER71's Avatar
mine bolted to the bed side of the cross member...i saw another one in a junk yard the other day but its the kind of yard where only there guys pull parts for ya...spendy. if anyone else has pics that would be cool. im sure this style might work but i think the driveline lenths would be different.
Old 03-27-2010, 06:30 PM   #4
royo
royo's Avatar
does this help
nickle and dime
royo is offline   Reply With Quote
Old 03-27-2010, 08:14 PM   #5
FOREVER71
FOREVER71's Avatar
nope neither of those...anyone else help?????
Old 03-28-2010, 12:17 PM   #6
Todd68Chevy
Todd68Chevy's Avatar
This one is probably not correct because it is off of a 68 coil spring truck but maybe it will show you something. It would use the carrier bearing like the one with 2 bolts in a line posted buy ROYO. TTT for you anyway. Good luck and happy searching.
Note: All parts I have for sale are also for sale locally.
I currently own: 1940 Chevy Fire truck (project), 1946 Chevy truck (project), 1946 Chevy 1 Ton pick up, 1953 Chevy school bus (storage area), 1968 Chevy C10 (I have drove for 26 years), 1994 Chevy C2500 (daily driver), 2005 GMC crew cab K2500 (parts hauler) and more trucks for parts.
Todd68Chevy is offline   Reply With Quote
Old 03-28-2010, 01:03 PM   #7
FOREVER71
FOREVER71's Avatar
i had no idea they had so many different brackets...thanks for ypur time in posting the pics.someones got to have the same style i had though...i think we are almost out of options.
Old 03-29-2010, 04:15 AM   #8
sameyrasmea72
sameyrasmea72's Avatar
What engine did your truck come with? BB is different than SB
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 03-29-2010, 03:42 PM   #9
FOREVER71
FOREVER71's Avatar
thats the one...my truck is sb.350. thanks for the pic.now i just need to find one.
Old 03-30-2010, 06:58 AM   #10
w314speed
Does it attach to the frame crossmember with 2 bolts or 4 bolts. I have both $25 for 2 bolt and $35 for 4 bolt plus shipping. LMK, I can send pics. Thanks, Dan
w314speed is offline   Reply With Quote
Old 03-30-2010, 10:24 AM   #11
FOREVER71
FOREVER71's Avatar
cool post some pics of what you have.i dont remember if it was 2 or 4.ill get some pics up of my available mounting holes.
Old 03-30-2010, 01:32 PM   #12
w314speed
The 2 hole is the black one and will need to use a bolt and nut to attach, as the threaded holes were partially drilled out. A grade 8 bolt and nut will be better than factory. the 4 hole has the old bolts in it. LMK
Old 03-30-2010, 03:13 PM   #13
Mt Man Chad
Mt Man Chad's Avatar
Here a original 2 bolt bearing carrier from 70 C20 with newer bearing, currently being used on a 68 C10 SWB.
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps.
68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread
Mt Man Chad is offline   Reply With Quote
Old 03-30-2010, 09:27 PM   #14
FOREVER71
FOREVER71's Avatar
pretty sure its the four bolt...ill send ya a pm shortly..jeremy
Old 01-26-2013, 05:31 PM   #15
dsudzina
Originally Posted by royo View Post
does this help
Royo,
I need to buy the pair of carrier support brackets like the one on the right in your picture. Do you still have it. My 69 is a C20 with 396.
Thanks, Dave
dsudzina is offline   Reply With Quote
Old 01-26-2013, 09:03 PM   #16
daddymoo2
Here are some pics of bracket willing to sell. Asking 25.00 shipped to you. Thanks
daddymoo2 is offline   Reply With Quote
Old 01-27-2013, 06:16 PM   #17
dsudzina
Hi,
I want to purchase the 2 brackets, but want to make sure we are talking about the same parts. I tried to attach a picture of exactly what I need but could not?? I am somewhat new to the site....
In your picture it is the 2 piece driveshaft on the right. The 2 triangle shaped brackets are bolted together by 3 bolts with the carrier bearing and rubber bushing sandwiched inside. These 2 support brackets bolt to a bracket on the center frame support, different than the ones in the pictures. I have the attaching bracket and one of the two triangle shaped brackets that the driveshaft goes through and holds the bearing.
I need the 2 triangle shaped brackets.
Thanks, Dave
