03-27-2010, 12:01 PM | #1 |
printing is my trade
floor pan replacement question
I'm fixin to put in one of those floor pan panels on the drivers side.
The panel I got runs from the hump out to the inner rocker. It looks like the weight is resting on the structure underneath. Can I cut all that out with the cab still mounted to the frame?
Jojo's '70 stepside build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=344184 |
03-27-2010, 03:03 PM | #2 |
Re: floor pan replacement question
Yes but I would only cut out whats needed and leave the good. Its rare to have to use the entire panel.
03-27-2010, 05:42 PM | #3 |
- I would only fix the floor of a truck when it was bolted to the frame - to keep the integrity of the truck intact to make the repair.
Clean back the rust in the floor to good metal than go 2-4 inches outside of that cut out crappy floor trim patch to approximate floor patch needed lay patch over existing floor and hole you created use an awl or a marker and trace around the patch laid on top of the old floor trim back original floor using the outline you just created lay patch in and trim/grind until it can be butt welded in |
