03-27-2010, 12:08 PM | #1 |
Big Block Exhaust?
HI ...I'm the FNG here, I've got a 64 stepside I want to put in a 454. I'm finding parts, but exhaust headers seem to be and "issue". Anybody every have to deal with this problem? ...What did you use, OR suggests?
03-27-2010, 02:43 PM | #2 |
Jonny
Re: Big Block Exhaust?
I've never done this before myself, but I would think that a set for a 73-87 would fit. I know they would clear the cross member and they should clear the floor pan. I had a set of headers off of a 80-something 350 on my 350 in my panel and they fit fine. If nothing else I'm sure that shorty headers would work.
1966 C30, Cummins, stacks, and a flat bed in progress... "Honor.....simply put, A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it." -AEC Hundley USNR |
03-27-2010, 03:31 PM | #3 |
If you use a tubular trans crossmember (like the CPP one) you can run 70-81 camaro headers also. Altho unless your looking for 2" primary or bigger headers the 73-87 truck headers are a better way to go. Its just hard to find big tube headers for trucks
03-27-2010, 03:33 PM | #4 |
Resistance is Futile
I tried the BBC shorty's based on your post before and they do work...............Hedman 68610.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
03-27-2010, 03:52 PM | #5 |
I should mention I also use solid motor mounts and tubular perches. Once again either the CPP or fabricated ones. this gives extra clearance as well.
03-27-2010, 05:13 PM | #6 |
Well a SB probably would have been smarter, but I never claimed to run in that group. I always like the "look" of big engines ...Hemi's & BB's, plus I already have a 454 ready to go! So that's a mute point.
I have a old set of hooker headers out of a 70 El Camino maybe I'll try "massaging" those ...but it'd be nice just to buy something "nice" that fits and with no "issues"!?? |
03-27-2010, 03:31 PM | #7 |
I am doing this right now. Putting a BBC in a 60-66 is easy; hooking everything up is a PITA I'm finding out.
What fits and what doesnt is related to what mounts one uses and where you decide to locate them. Using 73-87 1/2 ton mounts headers that will fit are: Hedman 69110........these are longtube for 73+ trucks and hang below the front x-member, so if your low you will be dragging them. Hedman 68610....shorty's for Chevelle/ Camaro. Require some slight clearance around drvrs side clamshell. Excellent clearance but slightly tite on the fitment. Sanderson QP2000's......cant get a dipstick in the oil pan. If you are not prepared to run into some mods, go smallblock. I'm reaching the frustration point with this swap right now, but think I have almost all the issues done. Again, this stuff works with only stock mounts from 73+ adapted to the 63-66 frame. If aftermarket or sb mounts are used I dont know what will fit.
03-27-2010, 08:37 PM | #8 |
Sence everyone seems to have pic.s, I have afew to share too.
03-27-2010, 10:34 PM | #9 |
73-87 headers will work but they don't clear the left motor mount perch. Here is what I used.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
04-01-2010, 11:30 AM | #10 |
In my experience it wasn't the headers causing the problem, but the engine mounts. I went with a set of BBC mounts from 67-71 to get the headers to fit.
'66 C20 converted to C10, 454/TH400 '66 C10 saved from crusher |
04-01-2010, 12:55 PM | #11 | |
It's Better With Nitro
Hedman shorty headers: ...downpipe rounted to the outside of the frame... ...rest of exhaust:
