C10 CLUB Y QUE!
1993 chevy burban 4x4
i had this 4x4 for few years now and now just recently blow a head gasket
money is short so decided to rebuild it myself .. i thought for min there i had it fix but after a week of driving it it started smoking really bad so now i have to redo it and take the heads to a shop... ![]() i was thinking maybe selling and parting the engine and tranny for my 65 does any one know if there is any parts from this 4x4 chevy burban that i can use for my truck example: a arms,power steering, disc brakes,Mc,rear end Last edited by Sick5; 03-27-2010 at 05:42 PM. |
C10 CLUB Y QUE!
Re: 1993 chevy burban 4x4
anyone?
find a 60-66 suburban body put in your 93 frame rebuild the motor and have a nice daily driver just my opnion
![]() Last edited by rebel714x4; 03-27-2010 at 06:55 PM. |
#4 | |
C10 CLUB Y QUE!
im thinking pull tranny and engine and the front seats wonder how can i use the tbi carb.. im sure i need the computer thats in the truck |
60-66 Nut
![]() ![]() Join Date: Mar 2007
The transmission won't work since it is a 4wd style. You will need to find a 4L60E that is a 2wd version if you want to retain the EFI. To use the EFI from the '93 Suburban, you will need all the engine and trans wiring harness as well as the ECM to control it all, plus an EFI fuel pump. This conversion can be overwhelming for someone that doesn't have a lot of mechanical/electronics experience as it requires that all the sensors be in place and possibly a modified EPROM for the ECM. You could always convert the engine to a carburator and bolt up a TH350 or a 700R4.
#6 | |
C10 CLUB Y QUE!
so i fig i would just exchange tailend of the tranny and sell the the one that needs rebuilding and as far as the efi stuff goes nice thing is not to many sensor on this year but ill just bolt on a carb instead could i use the Master cylinder of this truck or the power steering componets |
C10 CLUB Y QUE!
CaptainFab,
nevermind i found i can use Mc Just need a bracket you sell |
60-66 Nut
I could be wrong, but I believe that transmission would be the 4L60E, which is the electronic version of the 700R4. If so it will need the computer to operate or a aftermarket standalone controller ($1000.00-$1200.00). Either way you can't just bolt on the 2wd tailshaft housing, you need to change the output shaft as well. That requires a complete disassembly of the transmission.
C10 CLUB Y QUE!
Holy moly
dam your right!!!! well thanks im thinking CRAIGLIST!!! maybe ill find someone willing to trade Last edited by Sick5; 03-29-2010 at 02:51 AM. |
