Old 03-27-2010, 10:11 PM   #1
primetime
primetime's Avatar
diagonal
hey i got some trouble with my truck that i hope can be fixed with your advice. i'm going down the road at a weird angle. other than a bent frame, what can make this diagonal driving happen?
1968 Chevy C10 swb fleetside
2005 Chevy Silverado crew cab (SS)
1977 Goldwing cafe racer
1977 Chevy nova (first car/ first love)
primetime is offline   Reply With Quote
Old 03-27-2010, 10:24 PM   #2
bitchin85
bitchin85's Avatar
Re: diagonal
bad alignment probly.. was it ever in a wreck that you know of?
"I'll keep my guns, money, and freedom. You can keep the "change"
bitchin85 is offline   Reply With Quote
Old 03-27-2010, 10:36 PM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: diagonal
Check your rear springs. If the alignment pin is sheared the axle could be running crooked.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-27-2010, 10:36 PM   #4
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: diagonal
first off are all the tires the same kind and type and SIZE??? check your springs and hangars then allignment
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 03-28-2010, 09:01 AM   #5
LONGHAIR
Re: diagonal
I have seen this several times, cars and trucks.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 03-28-2010, 09:34 AM   #6
primetime
primetime's Avatar
Re: diagonal
the guy i bought it from never informed me if it was in a wreck. so i don't believe the frame is damaged. he did tell me he tried or someone tried to lower the back end. i assumed that meant he did something with the rear springs. but they are leaf springs not coils. so i'm not sure how they went about this drop.nothing looks out of place to me.
Old 03-28-2010, 09:40 AM   #7
bitchin85
bitchin85's Avatar
Re: diagonal
n2truck could be right. if lowered the back by removing some leafs, thes the pin in the middle of the springs could be broken, cut, or even missing. i would measure from the edge of the tire to the front edge of the wheel well on both sides and make sure they match, also coult the leafs on both sides and make sure there is the same ammount on both sides. iknow it sounds dumb but ive seen people do worse.. trust me. if thats all ok, then i would say alignment. or mis-matched tires or really uneven tire pressure
Old 03-28-2010, 10:02 AM   #8
James McClure
One shot, one kill.
Re: diagonal
Primetime, this condition is called "dogtracking", and is caused by the rear axel not being square with the frame. There are only a few causes for this out of square condition. Depending upon how far it's out it isn't easy to spot. Number 1 is the frame itself and this can be checked by finding 2 locations on the front of the frame and 2 out back. Using a plumb from each, mark the floor and move the truck off the area and measure from LF to RR and from RF to LR. Measurements should be the same within 1\4". Ideally they would be identical. Next would be rear springs. To check this (assuming frame is square) find a spot on each frame rail that is in the same position. Measure from there to the center of the axel at the inner "U" bolt. They should be the same. If not, look for "rust trace", an orange powdery rust, it's a good indicator where something is shifting that shouldn't be. Look for broken springs and like N2TRUX said, spring center bolt and assorted mounts. It doesn't take alot to cause this. 1\4" at the rear axel can be a foot by the time you get up front, so look carefully. Jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
Old 03-28-2010, 11:56 AM   #9
primetime
primetime's Avatar
Re: diagonal
yup,i see it. i looked underneath and my leaf springs seem misaligned. i see the powered rust areas. and also where it appears i'm missing one or two leafs per side. i don't know how many suppose to be stacked on one another.
is this something that can be fixed quickly or doe it have to be done by professionals?
Old 03-28-2010, 04:23 PM   #10
James McClure
One shot, one kill.
Re: diagonal
OK, glad I got you on the right road, now, check the other stuff as time permits. Your going to have to replace the springs if they have broken leaves. Generally, ok, half ton trucks have 4 leaves and 3\4 tons have 5. You could put 20 in if ya wanted. Seriously, think about what you carry, then select the spring. I haven't a clue as to cost, so call spring shops. Get new bolts, and "U" bolts for sure. I recomend using a sawsall to cut old bolts. Just torch the old "U" bolts. Cut on the INSIDE of the shackle or hanger and spring will fall out. Just be real careful not to cut into shackle or hanger. You don't want to try to unbolt them and try to get the bolt out of the sleeve in the bushing, WAYto much work. Good luck, Jim
Old 03-28-2010, 04:55 PM   #11
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
Re: diagonal
depending on which springs broke just remove them. as far as torching thoe old bolts off... thats up to you. I've always soaked the bolts with some penetraing lube and let it soak... zapped it with a impact.. you could go to 4 wheelparts and grab a new centering pin... and just cut it to size. all in all its something that doesnt have to go into a shop unless you just cant crawl under your truck for some reason.
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 03-31-2010, 01:24 PM   #12
primetime
primetime's Avatar
Re: diagonal
hey can someone post a pic of their leaf springs. i have 2 thin leaf springs on top of 1 thick one per side. i want to see how far off i am from correctness. also, the end of my springs have crazy angles to them where they mount to the bolt. almost looks like a 's'. i'll post a pic later when i get home.
Old 03-31-2010, 03:09 PM   #13
Keith Seymore
Keith Seymore's Avatar
Re: diagonal
r'uh r'oh - sounds like someone may have heated and re-arched the ends to lower the truck, and didn't get them the same side to side.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 03-31-2010, 08:42 PM   #14
bitchin85
bitchin85's Avatar
Re: diagonal
K
exactally what i thought. its a cheap, not so safe way to lower one of these.. heating and bending the springs weakens them..
Old 03-31-2010, 08:57 PM   #15
primetime
primetime's Avatar
Re: diagonal
i got a few pics of the leaf springs with my phone camera.
Old 03-31-2010, 08:59 PM   #16
bitchin85
bitchin85's Avatar
Re: diagonal
yeah those were heated and bent.. and someone removed some leafs.. it works, but its not the best/safest way to lower a truck..
Old 03-31-2010, 09:06 PM   #17
primetime
primetime's Avatar
Re: diagonal
so there's no fixing this other than buying new factory leaf springs?
Old 03-31-2010, 09:08 PM   #18
bitchin85
bitchin85's Avatar
Re: diagonal
pretty much.. if i were you, id get new springs. 5 leafs i believe, and do a flip kit. it will ride better, and youll have about the same ammount of drop
Old 03-31-2010, 09:11 PM   #19
primetime
primetime's Avatar
Re: diagonal
this is how its sitting right now. the only problem is the dog tracking
Old 03-31-2010, 09:13 PM   #20
primetime
primetime's Avatar
Re: diagonal
what is a flip kit? what does it look like?
Old 03-31-2010, 09:36 PM   #21
bitchin85
bitchin85's Avatar
Re: diagonal
it moves the rear axle to the top of the leaf springs. i blieve it just comes with a couple brackets, and longer u-bolts
Old 04-01-2010, 10:12 AM   #22
primetime
primetime's Avatar
Re: diagonal
i found another post where someone said they are going to install a flip kit on his truck. so i'll be following his progress to see the before and after pics. guess i'm looking to buy a new set of springs and flip kit before i can drive my truck again.
Old 04-01-2010, 10:14 AM   #23
Adams74Chevy
Adams74Chevy's Avatar
Re: diagonal
I'd call around to the local junkyards to see if they've got anything.
2006 Silverado Crew Cab 1500 4x4 5.3L automatic
1986 M1008 CUCV 6.2L Detroit Diesel TH400 4.56 Detroit Locker rear NP208
1973 K20 "Silverado" 350ci, HEI, TH350, NP203 with 2wd conversion, A/C, power windows,tilt wheel, dual tanks. My '73ish K20 thread My 5yo son claims it as his.
1987 V20 Custom Deluxe 350 TH400 NP208 "farm truck" getting parted out.
2016 Nissan Altima grocery getter/commuter
Adams74Chevy is offline   Reply With Quote
Old 04-01-2010, 10:38 AM   #24
primetime
primetime's Avatar
Re: diagonal
i wish i had realized last week what was going on with my leaf springs. now i'm back in WV and the closest pull-a-parts is 2hours away in Canton,Ohio. so for convience sakes i'll just buy some new ones from somewhere. do napa,carquest,autozone sell those?
