Old 03-27-2010, 10:44 PM   #1
Coreyterry
Coreyterry's Avatar
passing gear
im having problems with my transmission, its a th400. when it goes to shift from 2nd to 3rd its slips. but it only slips when the rpms are low. when i puut my foot down it shifts fine. i changed the modulator valve and it helped a little bit. also when i manually shift from 2nd to 3rd its shifts fine. what i was wondering is if there is suppost to be a passing gear on the 400s? if this is even the problem then thats great but if someone might know what exactly it is then i would be happy to know.
Coreyterry is offline   Reply With Quote
Old 03-28-2010, 09:08 AM   #2
JimKshortstep4x4
Re: passing gear
The Th-400 has an electric operated passing gear where the detent switch downshifts the transmission to second gear. This would most likely not have anything to do with your upshift from 2 to 3.
Outside of a low fluid level this problem is probably internal as it could involve the pressure regulator valve or the control valve assembly.
I am assuming that you adjusted the modulator valve when you installed it and that there are no vacuum leaks.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 03-28-2010, 09:59 AM   #3
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: passing gear
"Passing gear" is when the transmission downshifts from 3rd to 2nd when you mash the throttle. If your detent cable isn't hooked to the carb... it won't downshift. I don't know about it being "electric"...
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 03-28-2010, 10:02 AM   #4
OhOneWS6
OhOneWS6's Avatar
Re: passing gear
Gary
The Turbo 400 does not use a cable. It is electronic. There is a switch on the gas pedal. There is no detent cable from the carb to the trans. Someone posted a pic recently. I'll see if I can find the thread.
Like Jim already said. Doubtful that is your problem.
OhOneWS6 is offline   Reply With Quote
Old 03-28-2010, 10:13 AM   #5
GASoline71
GASoline71's Avatar
Re: passing gear
I learned something new today... which is what is cool about these boards. I had no idea even the old TH400's from back in the day were electronically shifted. Cool...
Still passing gear is a downshift from 3rd to 2nd... not the other way around.
Gary
Old 03-28-2010, 10:19 AM   #6
OhOneWS6
OhOneWS6's Avatar
Re: passing gear
Gary
LOL. Yep. no way around that.
This is not the thread I was thinking but same info here.
http://67-72chevytrucks.com/vboard/s...d.php?t=350456
Old 03-28-2010, 10:23 AM   #7
GASoline71
GASoline71's Avatar
Re: passing gear
Awesome! Thanks for the linky!!!
Gary
Old 03-28-2010, 04:37 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: passing gear
the TH400 electrick kickdown is for going into first gear. Even if you unplug it, you'll still get the 3 to 2 kickdown.
Either way, fluid level, or clutch wear is about the only thing that'll cause slippage.
Old 04-02-2010, 10:54 PM   #9
Coreyterry
Coreyterry's Avatar
Re: passing gear
OK well how would i go about buying a passing gear or whatever its called. im a noob and don't quite know all the terminology. about ok how much will the parts set me back?
Old 04-02-2010, 11:05 PM   #10
Sinister
Between Trucks...
Sinister's Avatar
Re: passing gear
Not sure on the price of a stock kickdown setup. Might check out the Parts Board. Somebody on here said you can run a carb mounted nitrous microswitch for the kickdown, which would probably be cheapest. I'm running the Lokar setup which runs about $100.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 04-03-2010, 12:11 AM   #11
Chevydude56
Chevydude56's Avatar
Re: passing gear
B&M setup, attaches to carb linkage
http://www.jegs.com/i/B%26M/130/20297/10002/-1?CT=
Installation article for B&M kit (not a truck , but you get the idea ) good pics
http://www.highperformancepontiac.co...all/index.html
original style switch ,mounts near gas pedal
http://www.americanclassic.com/Googl...70NOS-1970.htm
1967 Suburban 292 3spd
1964 Chevy II wagon
1971 Monte Carlo 402BB
1964 Cadillac series 62 2dr
1964 Bonneville 2dr/ht
1967 GTO
1978 Chevy Van 30
1989 R30 Crew Dually Bonus Cab
Chevydude56 is offline   Reply With Quote
Old 04-04-2010, 01:30 AM   #12
Coreyterry
Coreyterry's Avatar
Re: passing gear
ok well heres yet another problem, when i put it to the floor it takes a while to shift, in any gear. but if i have it to the floor its shifts fine from second to third. but at a low rpm like say cruising it slips about three or four times if not more before it decides to shift. like i said before though, when i manualy shift from second to third it shifts fine no slipping or anything.
Old 04-04-2010, 08:24 AM   #13
neba
Re: passing gear
have you checked your fluid? in park, engine running, pull dipstick, wipe clean and check level. what color is it? should be red to pink. if its brown your trans is toast. also check engine oil. radiators can break internally and mix trans fluid and antifreeze. passing gear/downshift has nothing to do with trans slipping. you can also drop trans pan. as clutches wear material collects in bottom of pan. if there is a large amount in pan also a bad sign.
neba is offline   Reply With Quote
Old 04-04-2010, 01:12 PM   #14
kwmech
Re: passing gear
On the pass side of the trans near the tailshaft there is a 4 bolt cover. That is where the governor is. Remove the cover and pull the gov out with a slight twisting motion. Inspect the nylon gear on the end for wear
