For 292 fans
"The truck man's truck engine" with "traditional virtues". The engine was a fleet favorite at UPS in tough stop and go delivery work before they went diesel in the 90's.
Re: For 292 fans
Wow, 280 ft/lbs is pretty good nice. If my truck came with a 292 i wouldn't swap it out
'72 cheyenne super step, '05 long bed gmc |
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
Re: For 292 fans
The 292 will taken out of the C60 I've bought and be going into the K10 project. When I was researching modifying my 250, the word was to treat the 292 like a Big Block.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
Six in a row makes it go...
![]() Join Date: Mar 2009
Re: For 292 fans
"It's lighter..."
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
Re: For 292 fans
Better pic's below
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 Last edited by aerotruk63; 03-28-2010 at 12:30 PM. |
Re: For 292 fans
Aerotruk - those images are great. Do you have them larger size or better quality? I'd love to be able to look those over...
Re: For 292 fans
Try this or print them.
http://picasaweb.google.com/normanme...eat=directlink
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 Last edited by aerotruk63; 03-28-2010 at 08:16 AM. |
Re: For 292 fans
Thanks! I'm glad somebody posted these, but they're a little tough to read. I'll have to try and track down the original document.
Re: For 292 fans
Re: For 292 fans
283=3" stroke,327= 3 1/4" stroke, 396=3 3/4" stroke,454=4.0" stroke. 292=4 1/8" stroke. The 292 is the original "stroker engine".
Re: For 292 fans
Switch the head from a 194 it's like a closed chamber head and you will up the compression ratio. Pertronix for the distributer for original look with a hotter spark. Iridium plugs. 8mm wires, Remove the oil bath guts and find a K&N filter with an adapter if necessary and install it in the stock air cleaner assembly. What else without machining or loosing originality?
Re: For 292 fans
Don't expect to spin it too much. Long stroke = high piston velocity for a given rpm = large loads on main bearings, rod bearings, and rod bolts.
#13 |
Re: For 292 fans
Thanks for the info..
I just purchased my first 1966 C20 Chevy truck and my first 292. So far (after power wash) the engine is showing the leaks. I have a rear main, pan, distributor, oil leaks. The carb needs rebuilt and the exhaust manifolds leak. Not but for a original engine! I am working on making it a daily driver. |
#14 | |
Re: For 292 fans
