Old 03-27-2010, 11:59 PM   #1
Geezer2
1982 3rd Member
Hello,
I have a 1982 Chevy 4x4. Just lost the rear end while casually driving on a rural road. Would someone be so kind to tell me how I identify the gear ratio?
I have pulled the rear cap and drained the oil.
My initial plans are to replace the rear end with one from the salvage yard. Some years back I replaced practically all body panels, engine and fresh paint. She's a keeper but current funds do not permit a new 3rd member. Any help will be much appreciated.
Geezer2 is offline   Reply With Quote
Old 03-28-2010, 12:22 AM   #2
Zoerb
Zoerb's Avatar
Re: 1982 3rd Member
You need to rotate the rear tires so you can see the ring, and stamped on the ring will be a number....
The number on the ring is almost unreadable, but the numbers will be on it similar to this.
for example this one says "15 41"
The gear ratio is 2.73
Hope it helps.
2017 Tahoe Premier - Daily
'99 Silverado 2500
Wife's whip- 2020 Equinox Premier
Zoerb is offline   Reply With Quote
Old 03-28-2010, 12:31 AM   #3
Geezer2
Re: 1982 3rd Member
Originally Posted by Zoerb View Post
Hope it helps.
Absolutely helps, thanks a ton. I will get on this Monday. Hopefully I can find the numbers, equate to a gear ratio and locate something used. Thanks again
Old 03-28-2010, 12:43 AM   #4
Zoerb
Zoerb's Avatar
Re: 1982 3rd Member
I forgot to add:
take the 41 and divide by 15. it comes out to 2.73333333333333333333333
'99 Silverado 2500
Old 03-28-2010, 07:16 AM   #5
Geezer2
Re: 1982 3rd Member
Yup, got it. Thanks
