Old 03-28-2010, 02:15 AM   #1
tim21391
tim21391's Avatar
door panel die/paint
has anybody done it before? i am going from green/white paint outside to yellow and white.. and there for im going to yellow dash with black carpet and black door panels but my panels are fine so i figured i would color them... whats pros and cons
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 03-28-2010, 06:02 AM   #2
OARNGESI
OARNGESI's Avatar
Re: door panel die/paint
If done right it can look as good as new but your better off buying the arm rests
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 03-28-2010, 08:01 AM   #3
LockDoc
The Older Generation
LockDoc's Avatar
I used SEM vinyl dye for interior parts on two of the trucks I built and it worked great for me. I scrubbed my parts with soap and water with a stiff brush, rinsed and dried, then went over them with a rag dampened with alcohol. If you have to touch the parts after they have been cleaned with the alcohol wear rubber gloves. You have to be sure and get all of the dirt and grime out of the grain of the vinyl.
Here is a good web site for information on SEM:
http://www.vinylprosem.com/
I agree with OARNGESI on the arm rests if you can get the color you want.
LockDoc
Leon
Old 03-28-2010, 09:12 AM   #4
Curbstone Mech
Active Member
Loc doc is right. The only other thing I would add is to use an adhesion promoter before you paint
68 short fleet
383 stroker, 700r4 373:1 posi
72 GMC 3/4 ton- weekly driver
700r4 351;1 posi
Curbstone Mech is offline   Reply With Quote
Old 03-28-2010, 03:54 PM   #5
tim21391
tim21391's Avatar
well i mgoin black so black armrest will be easy to get
Old 03-28-2010, 04:02 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I have done it on the 69/70 style vinal padded door panels on 2 trucks, and it holds up pretty good for 5 years or so, but then it starts to fade a bit. (I need to redo the longhorn's sometime soon-ish)
If you spray the dashpad, it'll be a tick more glossy than a new dashpad, and you may find the reflections a bit offensive, but it seems I am a bit picky on windshield reflections.
