Old 03-28-2010, 02:22 AM   #1
souza777
souza777's Avatar
Unhappy Need some shim help????
I lowered my 76 but the wheels are tilting in?? where do I need to shim to get them back straight again!!! If you have pics that would help alot to!!!!
Thanks!!!!!!!!!!
souza777 is offline   Reply With Quote
Old 03-28-2010, 08:55 AM   #2
LONGHAIR
Re: Need some shim help????
At the alignment shop. This is not something you can just do "until it looks right".
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 03-28-2010, 09:42 AM   #3
Restrorob
The One And Only !!!
Restrorob's Avatar
If you have a long distance to drive to a alignment shop you can add the same thickness shims to the upper control arm mounting bolts both front and rear bolts, Then you won't tear your tires up getting there.
But, As LONGHAIR said it needs to be done/finished by professionals....
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 03-28-2010, 06:21 PM   #4
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
just like he said, Harbor Freight has a shim kit for like 5 bucks... I used that same kit to align my truck (We have an alignment machine at work)
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
