Old 03-28-2010, 11:26 AM   #1
frankdatank01
Trim new springs?
Do I need to trim the ear on my new front springs to properly seat the spring in the bottom and upper grooves? Has anyone had to do this? See picture below.
1970 C10, stock spring height, ECE replacements
frankdatank01 is offline   Reply With Quote
Old 03-28-2010, 07:13 PM   #2
JimKshortstep4x4
Re: Trim new springs?
The spring should be right as it is. Your old spring has taken a set which affects the windup. This explains why the two won't match.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 03-28-2010, 07:18 PM   #3
72BlckButy
Tot Roddin'
72BlckButy's Avatar
40+ years of flexing will cause the spring to begin to sag... the old springs were as high as your replacements back in the day.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 03-28-2010, 08:30 PM   #4
frankdatank01
I'm going to give it a shot. I wasn't concerned on the height, just whether the spring will sit in the grooves properly since the new spring appears longer. When I test fit the bottom in properly, the top didn't feel right, but its hard to tell, there is not much of a "nub" up there where the spring sits, just the center circle. Thought I'd ask first.
Thanks for the responses.
Frank
Old 03-28-2010, 09:06 PM   #5
OhOneWS6
OhOneWS6's Avatar
Any chance you could measure the height of those old stock springs and report the results in the thread linked below? Even better if you can measure the wire diameter too. I know you truck is a 70 but I think the springs were the same from 70 to 72.
Thanks in advance,
Matt
http://67-72chevytrucks.com/vboard/s...d.php?t=394251
OhOneWS6 is offline   Reply With Quote
Old 03-28-2010, 10:02 PM   #6
Trip59
Who needs sleep...
Trip59's Avatar
Bottom has a place to seat, to locate, top doesn't, it's the same all the way around on mine...
Trip
Trip59 is offline   Reply With Quote
