Old 03-28-2010, 01:49 PM   #1
KungPowMinchow
Shave gas filler doors
Does anyone know where u can find like a patch panel for the square style gas filler doors for a 86 fleetside? cause im converting from my side saddle tank to an aluminum tank that mounts behind my rearend and wanted a cleaner look for the bedsides by having the doors shaved
KungPowMinchow is offline   Reply With Quote
Old 03-28-2010, 02:05 PM   #2
Panelman55
Panelman55's Avatar
Re: Shave gas filler doors
That one should be easy to make, or start by welding the door shut first. I can cut you out one if you need it, and don't find one. Check in the vendor section.
In God We trust!!!
Panelman55 is offline   Reply With Quote
Old 03-28-2010, 02:34 PM   #3
KungPowMinchow
ive thought bout welding the doors shut but on the drivers side theres a lil recessed area on the bed side so that u can open the fuel door easier
Old 03-28-2010, 08:10 PM   #4
thrtsxchambers
thrtsxchambers's Avatar
I have heard of people welding it shut then making a filler for the recessed area. I have seen some people unfold the sides of the door to fill the gap better also.
thrtsxchambers is offline   Reply With Quote
