Old 03-28-2010, 05:14 PM   #1
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
How bad is This Screw-Up?
I removed the pinion yoke without indexing/marking the nut,shaft and yoke orientation.:redface: What are the negatives involved in this "oversight"? Im installing a posi axle and wanted to replace all the seals. I knew better, but I had the thing off before my brain kicked in. Thanks guys!
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 03-28-2010, 05:46 PM   #2
Wrenchbender Ret
Re: How bad is This Screw-Up?
No problem. Clean the treads good & put some thread locker on the nut. Snug it down & tighten it a little at a time till you can feel a slight drag when turning the yoke back & forth. There should be no free play up & down on the yoke.
Wrenchbender Ret is offline   Reply With Quote
Old 03-28-2010, 08:00 PM   #3
Ironangel
Ironangel's Avatar
Thank you Lenexa!
"Two Seventy Two's"
02 3/4 ton Express
Old 03-28-2010, 08:02 PM   #4
Ironangel
Ironangel's Avatar
Re: How Bad is This Screw-Up?
delete
"Two Seventy Two's"
02 3/4 ton Express
Old 03-29-2010, 03:02 AM   #5
MT71c-10
Too many toys,not enough money
MT71c-10's Avatar
Did you just remove the drive shaft from from the pinion yoke, or the the pinion shaft from the diff housing, and pull it from the ring gear.
If it just the drive shaft, no problems no ballancing there. If it was the pinion shaft out of the housing from the ring gear, do as Wrenchbender says. You may want to install new crush bushing though.
Looking for all Montana members. PM me or send friend request.http://www.67-72chevytrucks.com/vboa...36#post3813336
MT71c-10 is offline   Reply With Quote
Old 03-29-2010, 06:46 AM   #6
68C15
blood type; Retumbo
68C15's Avatar
sometimes the shaft is balanced to the yoke, rare but possible. if it vibrates just flip it 1/2 turn and go.
there is no way to balance the yoke to the pinion. no reason to be concerned unless you get the pinion nut loose or too tight. IIRC 15-25 inlbs. of force should be required to rotate the pinion yoke with axles removed. a little more with axles installed.
68C15 is offline   Reply With Quote
