Old 03-28-2010, 05:56 PM   #1
dyno
dyno's Avatar
73-80 Hood Interchange?
I'm in the middle of a build and need to replace the hood on my '80 K20 due to rust pin holes in the nose.
I found a good hood off a '73 but have not bought it yet. Will it fit? Inside latch release problems?
I also hear there is some detail change on the nose of the '80.
"Built- not bought"
1958 GMC 150 4x4 in progress
1980 K20- Restored
1985 K3500 Flatbed
58 GMC 4x4 build thread:
http://http://67-72chevytrucks.com/vboard/showthread.php?t=557675
dyno is offline   Reply With Quote
Old 03-28-2010, 06:06 PM   #2
wedgemon
wedgemon's Avatar
Re: 73-80 Hood Interchange?
79 & 80 would have a moulded relief on the nose of the hood. Otherwise, 73 thru 80 all fit the same.
- Dave
2003 Silverado K1500 Z71 - Arrival Blue
1973 K5 Cheyenne Blazer 350/TH350/NP203
Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift.
RETIRED: 1980 Scottsdale 4x4
Founding Member:
"TILT WHEEL BELLY." Club
wedgemon is offline   Reply With Quote
Old 03-28-2010, 06:37 PM   #3
jrsmith_2010
I like turtles...
jrsmith_2010's Avatar
i just had to swap the latches when i did mine, other then that it worked just fine
1979 Silverado- lowered 5/7, 20 inch Boss rims, everything shaved, caddy lights, billet interior, UP FOR SALE!
1983 Scottsdale-on the back burner...SOLD!!!
1992 Silverado- extended cab, stock for now, but no promises SOLD!!!
2006 Chevy Cobalt-college car, staying stock
Whatever can't get fixed with a hammer, a roll of duct tape, a clothes hanger, a tube of glue, and a case of beer, can wait until tomorrow.
jrsmith_2010 is offline   Reply With Quote
Old 03-28-2010, 08:47 PM   #4
USSkoval
'77 was the first year for the change at the front of the hood, and also the first year for the optional inside hood release. If you have the inside release, you will need to cut a hole in the underside of the hood for clearance of the safety hook. If you need to do this, just measure from your original hood, then cut the hole.
USSkoval is offline   Reply With Quote
Old 03-29-2010, 09:19 AM   #5
dyno
dyno's Avatar
OK thanks guys. I think I'll try to find 77 and up for replacement. I like the look of the relief on the nose.
"Built- not bought"
1980 K20- Restored
1985 K3500 Flatbed
