Old 03-28-2010, 07:21 PM   #1
dyno
dyno's Avatar
Removing glovebox lock
What's the trick to remove the glovebox latch on 79-80? I see small hole in knob. Need to remove it for painting.
"Built- not bought"
1958 GMC 150 4x4 in progress
1980 K20- Restored
1985 K3500 Flatbed
58 GMC 4x4 build thread:
http://http://67-72chevytrucks.com/vboard/showthread.php?t=557675
dyno is offline   Reply With Quote
Old 03-28-2010, 09:21 PM   #2
CoggedBelt75
CoggedBelt75's Avatar
Re: Removing glovebox lock
Hope this helps...............
For key lock latches:
Lock the latch with the glove box open.
Use a straightened paperclip in the top hole (the hole pointing at the passenger seat with the glove box open) to push and release each of the tumblers one by one as you slowly remove the cylinder assembly.
For non-key lock latches:
Latch the latch with the glove box door open.
Use a straightened paperclip in the top hole (the hole pointing at the passenger door with the glove box open) to push and release each of the tumblers one by one as you slowly remove the cylinder assembly.
Unscrew the round piece from the outer side of the glove box door.
Joe
__________________________________________
1975 C10
"Questions are a sign of intelligence indicating a desire to eliminate ignorance"
CoggedBelt75 is offline   Reply With Quote
Old 03-28-2010, 09:59 PM   #3
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
i did a write up on another site.. theres a few pictures there too..
http://forum.73-87chevytrucks.com/sm...?topic=15274.0
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 03-29-2010, 09:16 AM   #4
dyno
dyno's Avatar
Thanks for the details. What a pain! I might just mask the chrome knob and paint it.
"Built- not bought"
1980 K20- Restored
1985 K3500 Flatbed
Old 08-18-2012, 08:32 PM   #5
MickMc
MickMc's Avatar
any one with pictures?
The other site no pictures either.
Mick
MickMc is offline   Reply With Quote
Old 08-18-2012, 10:43 PM   #6
masterlock
masterlock's Avatar
This helped me out a bunch
masterlock is offline   Reply With Quote
Old 08-20-2012, 05:55 PM   #7
MickMc
MickMc's Avatar
Just what I needed.
Problem solved.
Mick
Old 08-20-2012, 10:38 PM   #8
slugish
Slugish
wish Ihad got this advice before I ripped mine out & ended up gluing it back on . Also when repainting it
slugish is offline   Reply With Quote
Old 06-28-2014, 08:12 PM   #9
Tuff 1986
Tuff 1986's Avatar
Nicely detailed.. Thanks!
Will I ever finish my 1986 stepper..
Tuff 1986 is offline   Reply With Quote
