Old 03-29-2010, 07:37 AM   #1
C10Silverado79
New Fuel Pump Question 350ci
I replaced a fuel pump on 250ci 6cyl 20 years ago and it was a 'no brainer' install. Looking at my manual, it says the 350's have some kind of connecting rod that activates the fuel pump. Are there any special steps or tricks in need to follow to replace the pump? Will the rod 'self center' against the fuel pump or do I need to align it somehow?
TIA
Steve
1979 C10 Silverado
1998 Camry 5spd
2005 Harley ElectraGlide
C10Silverado79 is offline   Reply With Quote
Old 03-29-2010, 08:45 AM   #2
ont_guy_38
ont_guy_38's Avatar
Re: New Fuel Pump Question 350ci
When you remove the old pump the rod will probably slide down and you will see it , sometimes they are so gummed up they stay up but anyways you have to make sure it is up to get the new pump in . Just hold it up with your finger
ont_guy_38 is offline   Reply With Quote
Old 03-29-2010, 10:00 AM   #3
bigarmzz
bigarmzz's Avatar
to get the rod to stay up in there, i've always used just a "dab" of bearing grease to cause the rod to stay put
done it this way for years without a hitch
1987 350 TBI lowered 5/7
bigarmzz is offline   Reply With Quote
Old 03-29-2010, 11:01 AM   #4
C10Silverado79
If the rod is dropped down will it prevent the pump from installing or will it install anyway. I don't want to install it wrong and then really hose it up when I crank the motor.
1979 C10 Silverado
1998 Camry 5spd
Old 03-29-2010, 02:34 PM   #5
bikes&bowties
bikes&bowties's Avatar
nope the rod will be in the way and the little "lever" on the pump wont go into location. it will make perfect sense when you pull it apart and see it. Good luck
bikes&bowties is offline   Reply With Quote
Old 03-29-2010, 03:23 PM   #6
hotrod_991
hotrod_991's Avatar
yes the rod will stop the lever on the fuel pump from going up. I have always taped the end of a small flat tip screwdriver so there is not metal showing and if the rod falls when you romove the pump. us the taped end of the screwdriver to push it back up enough to get a finger under it then slide the lever in. Its really simple once you look at it. Good Luck
"Buckle up I wanna try somethin!!"
"of course it will hold!, I welded it!"
1977 c10 under knife for full rebuild, 5.3l 4l60e drive rain swap, replacement frame and green repaint
hotrod_991 is offline   Reply With Quote
Old 03-29-2010, 05:42 PM   #7
crm318
Alright Alright Alright
crm318's Avatar
I have put a small bit of silicone (I was already using it on the gasket) on the pushrod and it works every time.
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 03-30-2010, 07:44 AM   #8
C10Silverado79
I put the new pump on last night. It wasn't too difficult (as long as I did it right) I have some more things to put back together on the motor before I can turn it over.
Thanks for the advise.
1979 C10 Silverado
1998 Camry 5spd
