03-29-2010, 11:02 AM | #1 |
53 4-link rearend in and 3inch white walls
Finally got the 4-link in last week and got my tires in on Friday so here are some pics... will notch the frame when my bag brackets get here Monday or Tuesday they should be here... I will get about another inch out of the stance when I notch the frame which will put the rearend touching the under side of the bed and the bed will be raised 1inch.. Went with 15x10 on the rear with 255/60R/15 and 15x8 on the front with 215/70R15 which I can turn the wheel inside the wheel well with the air out and still turn both ways without rubbing the inside of the fender COOL..Going with over the axle bags and brackets and attaching it to the notch and then making a 2inch spacer to kick the shock out on the lower bracket and weld to tabs on the notch also.. will get more pics when done,, camera was dead so these pics are from my phone..
03-29-2010, 11:05 AM | #2 |
Re: 53 4-link rearend in and 3inch white walls
pics
03-29-2010, 11:56 AM | #3 |
more pics
03-29-2010, 11:56 AM | #4 |
That looks great.
Those are the wheel dimensions I was wanting to run. What front end are you using, and what 4 link? Thanks in advance.
My AD Truck Build Thread 52 GMC one day laying on the running boards 2004 Chevy Crewcab. 3/5 and notched |
03-29-2010, 12:00 PM | #5 |
Total cost engineerings mustang II with tubular control arms with shock mount, airbags, front sway bar, 11-inch brakes...power rack, the rear is air technologies basic 4-link kit...
03-29-2010, 12:48 PM | #6 |
more pics
03-29-2010, 01:45 PM | #7 |
That's perfect!!! Did you move the axle centerlines at all? They are well-proportioned. Any pics of your frame build?
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
03-29-2010, 02:02 PM | #8 |
here a link in my build or just go thru my threads I've started
http://67-72chevytrucks.com/vboard/s...d.php?t=278711 |
03-29-2010, 02:08 PM | #9 |
Yes 3/4 inch back from stock location of axle when the old tubed axle was pulled on the centerline of the frame to the back of the truck,,,,...rearend is out of a 79 f-150 9inch only have to cut drivers side of axle was about 7 or so inches long 120.00 for new axle passenger side fits right on the mark in the wheel tub... went with 41/2 inch backspacing on the back and 51/2 on the front
03-29-2010, 10:35 PM | #10 |
looks sweet, nice stance
03-30-2010, 07:45 AM | #11 |
Yellow truck club
looks great with the wide whites my favorite. Gotta get them to rebalance that front tire if they can and move the weight to the inside of the rim.
................................................................ Brian ...... My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW 59 Chev Apache PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
03-30-2010, 09:21 AM | #12 |
Great Look truck! Thats the perfect size tire and wheel combo! Im wanting to run those on mine
1955 First Series Thriftmaster Blown 355 TH400, S10 Chassis,narrowed 9 Inch rear, air ride, 4 wheel disc brakes, 20s and 22s, |
04-05-2010, 01:01 AM | #13 |
Do you have any pics of the TCI IFS and do you mind asking where you got it and what the price was? Information on the air bag version is really hard to come by, I'm wondering what the differences are from the coil over version.
