Old 03-29-2010, 11:50 AM   #1
MobSled
MobSled's Avatar
C-Notch Details
This is the deal guys...
I lowered my 77LWB. Front is running 2.5 drop spindles with 3inch lowering springs and the rear has a flipkit. I'm looking at a 5.5/5 drop. Not too easy on the eyes. I want to get the rear another 2 inches down. I already have the shackels that will give me those 2inches I'm looking for but unfortunately as of now I only have a 2inch clearence between my frame and rear diff. Having said that time for the c-notch.
I tried searching the threads for some extensive info, without luck. My question is how do I cut the frame for a bolt in c-notch? I don't feel like paying a shop 300 bucks to get it done. If someone has details for me (what's the best way, tool to cut the frame with? What's the best way to drill the holes into the frame for the bolts on the c-notch?) Please chime in.
.02 greatly appreciated.
MobSled is offline   Reply With Quote
Old 03-29-2010, 12:13 PM   #2
joe1982
.. !WAR FEDOR! ..
joe1982's Avatar
Re: C-Notch Details
try the FAQ thread, there is a step by step how to on the c-notching. im on my work computer, so i cant post a link.
"san diego chargers #1"
joe1982 is offline   Reply With Quote
Old 03-29-2010, 12:29 PM   #3
MobSled
MobSled's Avatar
Re: C-Notch Details
Thank you for the reply, funny, spent hrs trying to find something on c-notching but have not checked the faq section haha.
Even better, if someone is located in SoCal around the LA LB area and has expirience doing this, let me know. I rather have one of the members do the job for me and pay them then a shop.
Old 03-29-2010, 12:37 PM   #4
MobSled
MobSled's Avatar
Re: C-Notch Details
Maybe I'm just retarded but I tried to find anything in the FAQ section and no luck. A link will be greatly appreciated.
Old 03-29-2010, 02:11 PM   #5
tommyd241
tommyd241's Avatar
Re: C-Notch Details
http://67-72chevytrucks.com/vboard/s...d.php?t=195566
'68 SWB Fleetside
'98 K1500 Silverado
tommyd241 is offline   Reply With Quote
Old 03-29-2010, 06:54 PM   #6
MobSled
MobSled's Avatar
Re: C-Notch Details
Read the write up twice, great write up. Still a question what's the best way to cut the frame??? Torch, saw ect... what am I looking at fellas?
Old 03-29-2010, 09:10 PM   #7
Envy
Envy's Avatar
Re: C-Notch Details
I cut mine with a angle grinder with a cut-off wheel. The c-notch plate covers up any over-shots.
Envy is offline   Reply With Quote
Old 03-29-2010, 09:22 PM   #8
tcb-1
Nothing to see here.....
tcb-1's Avatar
Re: C-Notch Details
if you have access to a reciprocating saw (tiger saw) I believe it would go easier. grind or hand file all the sharp edges off, then apply a good coat of rust preventative paint.
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 03-29-2010, 10:02 PM   #9
jjjmm56
jjjmm56's Avatar
Re: C-Notch Details
sawsall or cutoff wheel on a 4 1/2" grinder works for me
jjjmm56 is offline   Reply With Quote
Old 03-29-2010, 11:40 PM   #10
noonzor
Re: C-Notch Details
i did mine with a 5" grinder and a drill. bought the notches from cpp, came with instructions for how to line everything up. once i had the outline traced on the frame i set the trailing arms and rear end in place just to double check that everything was lined up and then i started cutting.
my .02
69 c10 Shortbox Build
http://67-72chevytrucks.com/vboard/s...d.php?t=360622
noonzor is offline   Reply With Quote
Old 03-30-2010, 07:53 AM   #11
MobSled
MobSled's Avatar
Re: C-Notch Details
Thanks for all the input guys, I'll go at it this weekend with a grinder and a cut off wheel. I'll post pics.
Old 04-02-2010, 10:31 PM   #12
MobSled
MobSled's Avatar
Re: C-Notch Details
Alright guys I just finished the cnotch install, I will post pics soon. Now I have a problem. I'm running shock extenders with oem shocks, they still bottom out while simply sitting in the drive way. I'm running a flipkit with 2inch shackels which is a 7in drop...
What's next, drop shocks with extenders or is there another way? I thought with a 7inch drop all I needed was shock extenders but I guess I was wrong...
Quick solution would be greatly appreciated. I need to solve this tomorrow.
Old 04-02-2010, 10:36 PM   #13
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: C-Notch Details
Shorter shocks.
The shock extenders help with the angle of the shock,... as well as allowing you to use the stock oem shocks,... with a flip kit.
You have added the drop shackle to your suspension,... so shorter drop shocks are in order.
Keith
Convert to disc brakes.
Old 04-02-2010, 11:00 PM   #14
MobSled
MobSled's Avatar
Re: C-Notch Details
Drop shocks with extenders???
Anybody ever ran different shocks from another car/truck that are shorter? Not trying to be cheap just trying to figure out all my options.
Old 04-02-2010, 11:26 PM   #15
joe1982
.. !WAR FEDOR! ..
joe1982's Avatar
Re: C-Notch Details
Yeah, I bought my shorter shocks off summit. They where about 60 fir the pair.
Old 04-02-2010, 11:32 PM   #16
MobSled
MobSled's Avatar
Re: C-Notch Details
I wish I had the time to wait and order the shocks, the bed is off the truck and unfortunately she's my dd besided my motorcycle. The weather here in Los Angeles isn't that great yet to rely on my bike. I need some shocks by the end of tomorrow.
If any of you guys in SoCal has some for sale, knows about a shop around LA that carries them or maybe knows of another car/truck shock I can use id appreciate the info.
Old 04-03-2010, 01:34 AM   #17
MobSled
MobSled's Avatar
Re: C-Notch Details
I think I found 2 shopps around here that may carry the nitro dropps...I guess my question is run the shock extenders and nitros or just the nitros on this 7 inch drop?
Old 04-03-2010, 10:28 AM   #18
Chevydude56
Chevydude56's Avatar
Re: C-Notch Details
Don't know if you are considering Monroe shocks, may be more available.You can look up the original shock then look up a shorter one with the same mount.
Here is a link to a Monroe catalog dimensions and mounting
http://www.monroe.com/catalog/docume...engthSheet.pdf
Monroe application catalog
http://www.monroe.com/catalog/ecatalog.asp
1967 Suburban 292 3spd
1964 Chevy II wagon
1971 Monte Carlo 402BB
1964 Cadillac series 62 2dr
1964 Bonneville 2dr/ht
1967 GTO
1978 Chevy Van 30
1989 R30 Crew Dually Bonus Cab
Chevydude56 is offline   Reply With Quote
Old 04-03-2010, 11:23 AM   #19
MobSled
MobSled's Avatar
Re: C-Notch Details
Thx for all the info guys, I found some nitros for 40 a piece in a shop 10 miles from here. I'm still wondering if I should run my shock extenders with my drop sshocks seem is how the shock are only made for a 5inch drop.
