03-29-2010, 01:50 PM | #1 |
Cal-Tracs
Cheapest place to get some cal-tracs for 85 chevy swb?!
Thanks, Shawn
Shawn 85 SWB 7.39 @ 93 Best so far with 0 tuning Lesson in life: Never fry bacon naked! |
03-29-2010, 02:00 PM | #2 |
Re: Cal-Tracs
73-87ChevyTrucks.com - Caltrac's
It's Capt Chaos vendor site... he's a registered Vendor here as well
Joe 1957 Chevy 3100 Stepside Last edited by Tezjoe84; 03-29-2010 at 02:01 PM. |
03-29-2010, 02:06 PM | #3 |
Re: Cal-Tracs
I'll check that out.. thanks alot
I've decided to build a 496 for my shortwide and im sure the factory suspension will NOT hold the power.. it doesnt really hold the power from the 355 lol. Shawn
03-29-2010, 02:10 PM | #4 | |
Re: Cal-Tracs
Yea, a 496 is what i'm planning to build as well... it's a while coming still... gotta but the heads, then I gotta buddy at a speed shop gonna help me assemble it all. Definately gonna be fun, but yea, at first I plan to run the caltrac's on my pickup, will definately be a test to see how well they work
Joe 1957 Chevy 3100 Stepside |
03-29-2010, 02:22 PM | #5 |
Re: Cal-Tracs
Yeah, my uncle has the hookup on stroker kits, im getting eagle crank and rods, je pistons balanced for $800 so i HAVE to go that route cause it's so cheap lol. I'm buying brodix race rite ovals 270cc. victor jr, unknown hydo roller, holley 1050 dominator, msd 6al2, im gonna run the morel type lifters for sure and prolly do a lunati cam or have a custom ground cam. It's definately gonna come alive lol. BUT I GOTTA GET OUTTA THIS SH*T HOLE COUNTRY FIRST. I come home in around 80 days then it's on like donkey kong lol.
Shawn
03-29-2010, 02:51 PM | #6 |
Re: Cal-Tracs
Sounds awsome!
I gotta cousin that just got home from over there. Thanks for your Service btw! I look forward to seeing yours going, sounds real close to what i'm gonna build, I'm using AFR's 305 head though, and a comp Hyd Roller. It definately should liven up the old stock big block it's replacing heh.
03-29-2010, 03:14 PM | #7 |
Re: Cal-Tracs
I've seen good numbers from 496's with the 305's from AFR. I'm using the RR's simply because people think "they don't flow well." People base off of flow numbers to much now. There is alot more important things to heads other than flow numbers. I'll let you know how the build goes ^^. I'm hoping for around 650hp but who knows. Maybe i can get into the 7's (1/8 mile) If not.. there is always the juice
Shawn
03-31-2010, 08:06 AM | #8 |
Re: Cal-Tracs
cal-tracs work just plain awesome
03-31-2010, 04:19 PM | #9 |
Re: Cal-Tracs
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
03-31-2010, 04:54 PM | #10 |
Re: Cal-Tracs
^Add me to that list of believers too. They work awesome after you get them setup correctly.
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs. Best time so far 11.8@XXXMPH |
04-01-2010, 08:22 AM | #11 |
mini truck racer
Re: Cal-Tracs
I had good luck with mine . The instuctions give you a starting point with preload settings , but if you have better track you can run some gap . I set mine up with about 7 different settings . I didn't use the bottom hole as it is better suited for poor track conditions . With the bar in the top hole my settings would go from the factory preload ( not so good track ) to flush with the leaf (better track ) to gapping with a dime or nickle depending on what the track will take . The bigger the gap the harder it "hits the tire" .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
04-01-2010, 08:32 AM | #12 | |
Re: Cal-Tracs
Great info. Did you set them the same side to side?
04-02-2010, 08:43 PM | #13 |
At the body shop.
Re: Cal-Tracs
I got mine from cal-tracs. 1.671 60ft foot braked on drag radials
" That didnt make it any newer " " Dont antique the equipment " |
04-02-2010, 09:04 PM | #14 |
Re: Cal-Tracs
can one of yall measure your bars? i want to compare them to the ones i made, im making my own traction bars and just curious.
04-03-2010, 08:13 AM | #15 |
Re: Cal-Tracs
Cal tracs are nothing like traction bars and really need their split leaf springs.
I made a pass with a buddies girlfriend in the orange 67 camaro last night. I went 1.61 60 on motor with a 275 60 15 mickey t radial and my buddy went 1.42 with the bottle and no passenger.
04-03-2010, 06:55 PM | #16 |
At the body shop.
Re: Cal-Tracs
[quote=djracer;3898160]Cal tracs are nothing like traction bars and really need their split leaf springs.
To bad they dont make them for pick ups tho... Last time i called them anyways
" That didnt make it any newer " " Dont antique the equipment " Last edited by KQQL IT; 04-03-2010 at 06:55 PM. |
04-04-2010, 10:05 PM | #17 |
60-66 Nut
Re: Cal-Tracs
Here are a couple pics I saved of a members truck that is running Caltracs. I neglected to save his user name though.
So apparently they make them that will work on a pickup. [quote=KQQL IT;3898843]
04-03-2010, 09:35 AM | #18 |
Re: Cal-Tracs
mine are similar, they will run from the axle housing to a crossmember or from the ubolt plate to the frame. i might make a post today about them.
04-03-2010, 07:21 PM | #19 |
Re: Cal-Tracs
I was told that they did make the split leaf setup for our trucks. I imagine it wouldn't be too hard for them to make some if needed. That's what I want for my truck next.
04-04-2010, 10:33 PM | #20 |
Re: Cal-Tracs
Good stuff Capt. I'm gonna go ahead and order some. Thanks for everyones help!
Shawn
04-04-2010, 10:54 PM | #21 |
At the body shop.
Re: Cal-Tracs
Im sorry if i wasnt clear. Last time i called cal-tracs, They didnt make a split mono leafspring for pick up trucks. my 73 wanted the light 3 leaf pack and both shocks pointed forward
04-05-2010, 09:21 AM | #22 |
Re: Cal-Tracs
Are those homemade shock brackets you have bolted to the caltracs? If so, that's what I need to do. I was planning to have my shocks mounted behind the axle and vertical, but I may see if I can try that forward tilt like yours.
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs. Best time so far 11.8@XXXMPH Last edited by team39763; 04-05-2010 at 09:24 AM. |
04-07-2010, 12:37 AM | #23 |
At the body shop.
Re: Cal-Tracs
Ya just angle iron bolted to the u/bolts, got the shocks back to a decent angle too.. A complete accident. But either forward or backward as long as there the same direction.
