Old 03-29-2010, 04:37 PM   #1
sizzle-fry
sizzle-fry's Avatar
Delrin?
Hey there - I didn't come up with much while searching the topic (delrin) so if this has been answered before please redirect me.
Where can one buy delrin bushings for rear control arms and front a arms? I haven't had much luck out there finding these on my own, do I need to have these made for me or does someone sell them for the 6772 trucks?
1968 C20 CST 327/T400
http://67-72chevytrucks.com/vboard/s...d.php?t=394124
sizzle-fry is offline   Reply With Quote
Old 03-29-2010, 04:59 PM   #2
PBFAB.COM
PBFAB.COM's Avatar
Re: Delrin?
Not sure if anybody makes a factory replacement delrin bushing for the front. You WILL NOT want to run a delrin bushing on a rear link suspension. The Delrin bushing offers no deflection and will bind-up and break if used on the rear.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 03-29-2010, 05:08 PM   #3
tommys69/454
1969 short box
tommys69/454's Avatar
Re: Delrin?
delrin is a trade name by the DuPont company it is really Acetal copolymer & or Acetal copolymer with PTFE lubricant msc (manhatten supply comp.) or grainger or i came across this company which I have never used. that sell it. basicly any place that sells plastics to machine shops would have it in bar or sheet form. http://http://www.professionalplastics.com/DELRINSHEET-ROD"]http://http://http://www.professionalplasti...ELRINSHEET-ROD[/URL]
tommy morehouse
tommys69/454 is offline   Reply With Quote
Old 03-29-2010, 06:24 PM   #4
sizzle-fry
sizzle-fry's Avatar
Re: Delrin?
Thanks for taking the time to reply to this post, hopefully it saves someone some wrench and safety.
I heard the stuff can take compression pretty well, I imagine that this deflection issue is coming from the twist force? fwiw my camero buddy explained he only uses a delrin on one side for this very reason.
Alternative is rubber or urethane I suppose - urethane gets rather squeeky. What is the most utilitarian upgrade for these rear control arm bushings? Would like to never have to change em out or have any trouble once they are replaced.
Old 03-29-2010, 06:25 PM   #5
sizzle-fry
sizzle-fry's Avatar
Re: Delrin?
Hey thanks a million for this link. I saw reference to sources of raw mats, even some machine shops who will cut/press for folks. I was hoping to find something sitting on a shelf somewhere of course, but this is good info to have.
Old 03-29-2010, 07:40 PM   #6
ERASER5
ERASER5's Avatar
Re: Delrin?
Yes delrin does take compression well. So does solid steel. Neither deflect and rebound. And under repeated stress, both can/will fracture.
Delrin is great for a lot of cool projects, this is just not one of them.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 03-29-2010, 07:45 PM   #7
cparman
sharp as a marble
Re: Delrin?
limited knowledge of delrin. Global West like delrin bushings, and has a bunch of info about delrin vs. polyeurethane. might be a good read.
Delrin does not deflect, like a rubber bushing? the steel bushings in our trucks do not either, and I think my old 69 rides damn sporty. my .02 worth
cparman is offline   Reply With Quote
Old 03-29-2010, 08:32 PM   #8
DKN
Active Member
Re: Delrin?
Delrin is very hard, does not stretch or deflect, is brittle, and squeaks. I have worked with delrin on racing trucks; I do not like it much. We use a different material for the bushings in our tubular control arms. It will never squeak, it is very strong, but it will deflect, has memory, and in impact testing it will not break. It is patented and manufactured under license by DuPont.
Danny Nix
CPP
DKN is offline   Reply With Quote
Old 03-29-2010, 09:07 PM   #9
orange71
Re: Delrin?
check out kartek.com if your interested in prefabbed delrin bushings
orange71 is offline   Reply With Quote
Old 03-30-2010, 03:46 AM   #10
vegaschevy
Re: Delrin?
I have never heard of Delrin squeaking, one of the things about it is that is a self lubricating material with whatever they do...
but unlike steel in a bushing the Delrin WILL shatter
vegaschevy is offline   Reply With Quote
Old 03-30-2010, 11:30 AM   #11
sizzle-fry
sizzle-fry's Avatar
Re: Delrin?
So its starting to sound like it would be most suitable for one to use rubber/OEM bushings in places like trailing arms and a arms (to avoid noise) and urethane for things like sway bar, torque bar, cab, motor mounts, etc.
That delrin stuff has been around for a bit so perhaps it really isn't suitable, hence no parts available.
The delrin camaro bushing application I saw (here: http://msperformanceonline.com/c10-201-del.html ) has a grease fitting (zerc) so even if it does self lub, looks like additional grease is required. No petroleum breakdown like rubber. If a beefed up camaro doesn't crush em... ahh whatever, can't find em for these trucks anyhow. Camaros don't take hard suspension hits when they are having a good day also. I could see where they might crush from twist under pressure.
Thanks for everyone chiming in, I was suprised that this question hadn't come up before actually. Any opinions on better than stock replacement options beyond urethane?
Old 03-30-2010, 04:35 PM   #12
vegaschevy
Re: Delrin?
Give you a few minutes to pull up some pics of crushed Delrin used on this very part on my Jeep...
all 8 arms broke like this
Old 03-30-2010, 04:57 PM   #13
crakarjax
crakarjax's Avatar
Re: Delrin?
I use polygraphite, it does not squeak.
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 03-30-2010, 06:43 PM   #14
SCOTI
SCOTI's Avatar
Re: Delrin?
I thought Delrin was best for smooth pivoting applications (front a-arms that pivot up/down only) & not recommended for pivot/articulation (rear 4-bar applications or 2-links) where bind is inherent to the design?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-30-2010, 08:23 PM   #15
DKN
Active Member
Re: Delrin?
This is a typical failure with Delrin. We replace the Delrin bushings in the race trucks almost every 500 miles. It usually cracks like you showed. It is very easy to machine, so we kept many replacments on hand at all times. We also used Delrin in the steering system, we often had to replace the Delrin a few hundred miles short of the finish for the Baja 1000; It just does not hold up all that well. I worked on researching new materials. The plastic in the CPP tubular arms is the best I have ever seen. No grease, No squeaks, and I have NEVER had one fail/wear out yet.
Danny Nix
CPP
