Old 03-29-2010, 06:28 PM   #1
entourageguy
Yellow truck club
entourageguy's Avatar
Well I finally did it ...
When I installed the 4-link and rear end 2 years ago I had planned to do small tubs in the box to clear the disc brake calipers that hit the box so I could get it to sit down.
I looked around and found a pair of bolt on box tubs from a mid 60's chev. They were too wide so I cut a 4" section from them to make them narrower.
Had them painted and there they sat for over a year. Well the weather has been warmer than normal and with a bit of heat in the garage I went at it.
Of course since I was doing this I thought I'd refinish the floor boards as well. Now the gas gauge was not working so I went at that at the same time.
Being painted had to take a bit more care. Lots of masking tape and triple measurment.
Here are few pictures and end result.
doesn't look like it but the boards were showing their age (8 yrs)
hardest part was cutting out the painted bed sides. It does not get cleaned under here very often...
Some of the bed boards reinstalled
Fitting the tubs
I was not happy with the look of the tub against the box side so I used some fender welt between them.
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 03-29-2010, 06:35 PM   #2
entourageguy
Yellow truck club
Re: Well I finally did it ...
last few pictures ...
off of kijiji I picked up a set of rally wheels 15 x 10 with 295/50 15" with the tags still on the them. Had the porta whites put on to see how they will work with the lower profile tires. Fills up the wheel well nicely and got rid of the 2.5" spacers...
still a bit of saw dust to get rid of
sits lower now ....
Brian ......
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
tilt, 4 wheel discs
4-link and bags
10 bolt limited
Old 03-29-2010, 07:01 PM   #3
4DSEVEN
4DSEVEN's Avatar
Smile Re: Well I finally did it ...
Looks great!
Nice find on the rims too.
4DSEVEN is offline   Reply With Quote
Old 03-29-2010, 07:24 PM   #4
Kabwe
Certified Car Nut
Kabwe's Avatar
looking good. Good job.
Kabwe is offline   Reply With Quote
Old 03-29-2010, 08:12 PM   #5
Tri5Nerd
Tripple Five Fanatic
Tri5Nerd's Avatar
Looks good, how much more difficut would it have been to put the tubs under the wood floor? I ask because I will be tubbing mine putting wood floor.
Tri5
1955 Chevy Stepside/LS1 drive train
http://67-72chevytrucks.com/vboard/s...d.php?t=371513
Tri5Nerd is offline   Reply With Quote
Old 03-29-2010, 08:19 PM   #6
rjs53
nice job
rjs53 is offline   Reply With Quote
Old 03-29-2010, 09:25 PM   #7
entourageguy
Yellow truck club
Tri5
You could do it that way just a lot more fitting of the floor boards. The factory strait sides have their tubs sitting on top of the floor boards and have more fitted tubs to acomodate the bed strips.
Brian ......
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
tilt, 4 wheel discs
4-link and bags
10 bolt limited
Old 03-29-2010, 09:56 PM   #8
JML55
JML55's Avatar
Nice work looks really good. I have the same issue with the calipers on my build but I'm still not ready to tube my box sides.
Jean-Marc Lacasse
57 GMC
55 GMC
55 Belair
99 S10
http://67-72chevytrucks.com/vboard/s...d.php?t=316140
http://67-72chevytrucks.com/vboard/s...d.php?t=806011
JML55 is offline   Reply With Quote
Old 03-29-2010, 11:04 PM   #9
tobins 52 gmc
tobins 52 gmc
i gotta see that truck in person ,looking good
tobins 52 gmc is offline   Reply With Quote
Old 03-29-2010, 11:59 PM   #10
Tri5Nerd
Tri5Nerd's Avatar
Thanks for this info, I didn't know that it's that way from the factory, plus it looks like it's a lot more work to get them under the boards.
Tri5
Old 03-30-2010, 07:39 AM   #11
entourageguy
Yellow truck club
Tri5
I think if you can find a set of factory 58-59 fleetside tubs to work with it will look even better.
Brian ......
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
tilt, 4 wheel discs
4-link and bags
10 bolt limited
