03-29-2010, 06:41 PM | #1 |
Opinions on Electric or Manual Fuel Pumps
I have been running an electric fuel pump on my Sons 64. It is one noisy son of a gun. Some times it sounds like its loosing its prime and then it really gets loud. What recommendations would you give as far as brands and type of Fuel Pump or would you go back to the Manual Pump? This is a 69 327 with a Slight Cam in it. I am running a 6 PSI pump in it now and is seems to be keeping up as long as it keeps its prime. I am still running the original fuel tank behind the seat if that makes any difference I did put a new Sending Unit and Gasket in it while I had the truck down for resto. Thanks for any advice you can give on this.
JRBECK64 |
03-29-2010, 07:01 PM | #2 |
Re: Opinions on Electric or Manual Fuel Pumps
i personally love the simplicity and dependability of a manual fuel pump. they never go bad and truck along, especially if your just running a stock setup.
that said, i hate how they have a delay in getting the fuel to carb when theyve sat for 12 hrs or more. gas in carb starts it up, but then it starves out waiting for the pump to supply to the carb. then again, there may b a quick fix to this problem, if so, i couldnt complain one bit about the manuals........ |
03-29-2010, 07:12 PM | #3 |
Shlong Bed Club
i personally prefer electric pumps. i was having a similar problem with mine until i learned that most electric pumps are better fuel pushers than pullers. after burning up 2 Carter round style pumps i moved it from the engine compartment to directly under the fuel tank under the cab (right where the steel line comes out of the tank, has about 6" of rubber line, then back to steel line) and never had a problem after that. the pump isnt particularly loud, you cant hear it with the engine running, only when KOEO. which i like cause it primes the carb after sitting awhile... just my $0.02
"If it ain't broke, hit it with a hammer, then fix it.." |
03-30-2010, 02:01 AM | #4 |
fan of "Butters" Stotch
Sorry, not big on electric pumps. They just don't seem to be reliable
If I did have to run one (like if I were to ever do an LSx swap), I'll have a tank under the bed, and the pump in the tank. Then again, this is just my idea in my scambled little head Stick with a stock mechanical pump. They are cheap, reliable, and can be fixed in a few minutes if you should have a problem.
64 shortbox fleetside replacing rusty junk with more junk, and one day to become a real truck again |
03-30-2010, 08:33 AM | #5 |
I am also a fan of manual fuel pumps.
You might want to consider an aftermarkey Holley manual fuel pump. I have used them on (2) different cars and they have worked flawlessly. I like them because you can position the inlet / outlet in different positions based on clearances and plumbing configurations. http://www.jegs.com/i/Holley/510/12-834/10002/-1 |
03-30-2010, 10:25 AM | #6 |
My 69 Chevelle with a 496 big block runs in the 11's at the drags at 114mph, with a Carter 172 mechanical fuel pump. There's no need for an electric pump on anything but a pretty radical race vehicle, in my opinion.
Carter makes the 172 for both BB and SB. |
03-30-2010, 12:39 PM | #7 |
Senior Enthusiast
In 5 decades of working on cars I've experienced one defective mechanical pump out of the box, with a pinhole leak in the diaphram. That's the only problem I've ever witnessed with a stock pump other than just plain wearing out from age.
In my youth I thought electric pumps were a must have because they made noise, and non-car people would think you were cool if you had one. Out of necessity I've run them on two relatively mild cars, mounted next to the tank. A 283 powered 54 Chevy driven roughly 100,000 miles and a 46 Ford sedan with a 350 that went 300,000+ in eight years. 3 different pumps failed during that time on each car. The last failure occured when my wife (then fiance) was driving. The car didn't tolerate anyone but me driving, so she quit running, leaving my fiance stranded in the hubcap lane during rush hour. After talking nice to the car and analyzing everything, it was determined absolutely nothing was wrong. So I did the next logical thing and beat the crap out of the electric pump with a 12" crescent wrench, she fired right back up and kept working until I sold the car. I'll never have another electric pump, they belong on race cars. For street applications that must run an electric pump, it's a smart idea to include a toggle switch for manual shut off and a roll-over cut off switch in the event of a crash where you can't shut off the pump manually. http://performanceparts.com/part.php?partID=430704 The toggle switch doubles as an anti-theft device, and it's just not a good idea to have the pump spewing gasoline all over a car you may be trapped in, another feature you won't experience with a mechanical pump.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
03-30-2010, 01:22 PM | #8 | |
I put a oil pressure switch in the system to shut off the fuel pump in case of roll over or wreck. I am seriously thinking about putting a manual pump back on this truck. The main reason I went with the Electric Pump was I had two mechanicals go bad on me within a year on this truck. I got tired of messing with it so I put the Electric on it. In the last 10 years I replaced one Electric pump and thats probably because I cheaped out when I put the first Electric Pump on it. I am interested in the Holley manual pump and I think I am going to look into it. Thanks for your time. JRBECK64 |
03-30-2010, 05:38 PM | #9 |
Senior Enthusiast
JRBECK64 - you have a PM.
03-30-2010, 11:20 PM | #10 |
I currently have two cars (one is a truck) with the basic Carter electric fuel pumps (sorry I don't remember the number, but is is no moreh than 6 psi). The 280Z does not have room for a manual pump and the truck is a vortec. Approximately seven years on the Z with no issues and so far about five on the truck. Both are running 600 cfm Elebrocks. So I can't complain, but all that said if I could run a mechanical fuel pump I would because a blown fuse will not keep it from doing what it is supposed to do.
D's 63 |
03-31-2010, 09:33 PM | #11 |
As far as Ive seen it dont matter if you go mechanical or electric. If ya go cheap you will have problems. Just buy a GOOD one and its good for 100k miles or more.
Regardless of what way ya go its always nice to have a cheap electric in the tool box just in case ya need it to get home. One thing I have noticed is watch where the pump is made! I got a pump for my nissan and it ran for years fine. one day it stopped. Tapped it and it started again but I figured I should replace it. Got a new one made buy the same company as my old one and it quit in less than a month. Brought it back and they gave me a new one and it too died fast. Took that one back and they gave me another one and its been running ever since. I looked at them and noticed my old one and last one had the label on horrizontal and the 2 that died were verticle. The 2 that died were made in China, the two that still work, USA. |
03-31-2010, 09:40 PM | #12 |
Like it was said earlier if you use an electric pump it must be set lower than the tank, electric pump don't develop much suction lift so its really hard to suck gas out of the tank, also these pump should really have a return line back to the tank to keep the pump from being dead headed against a shut needle and seat or regulator, this will keep the pump from overworking itself and overheating.
01-21-2012, 12:00 PM | #13 |
What about running both elect and manual,, would u all think that would work fine and if so will the elect pump run if I added a on/off switch,, cuz I have a jegs elect pump that is loud so I figured if I would put an on/off switch just to help push the gas through,, with the switch on off will the gas flow freely with the manual pump or will it not,, hope u can understand this lol.
Check out my Photos http://67-72chevytrucks.com/gallery/...ry.php?cat=769 L.L. N.M. 63 chevy c-10 67 chevy c-10 71 chevy Blazer 4x4 |
01-21-2012, 12:11 PM | #14 | |
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
01-21-2012, 02:43 PM | #15 | |
"Where were you in '62?"
That's what I did Bud. I use it on initial start up. You can not leave it on all the time because you will burn it up. Sorry for the big pictures. 555-15913 - JEGS Performance Products 15913 - JEGS Street/Performance/Race Electric Fuel Pumps Electric Fuel Pump Street 95 GPH Gasoline Only Pre-set to approximately 6.5 psi 555-15172 - JEGS Performance Products 15172 - JEG'S Fuel Filters Street Fuel Filter 2.45" diameter x 5.25" high 555-10564 - JEGS Performance Products 10564 - JEGS Fuel Pump Harness and Relay Kit Single Fuel Pump Harness and Relay Kit Fuel Pump & Regulator Install Kit. JEGS Performance Products 100804 - JEGS Fuel Pump & Regulator Install Kit JEGS Performance Products #555-100804 Fuel Pump & Regulator Install Kit 130 GPH Fuel Pump (555-15915) Fuel Pressure Regulator (555-15912) Filter, Fittings, Line, Line Clamps & Pressure Gauge http://www.jegs.com/i/JEGS+Performan...00804/10002/-1
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
01-02-2013, 12:01 PM | #16 |
Question on switching to electric. What do you do about the hole in the motor where the manual pump was? Do they make something to cover it up? The reason I ask is, my manual fuel pump was acting up, when I went to remove it, the bolt broke off. I couldn't get it out. I tried an easy out and it only made things worse. Now, I have a larger hole that I can't seem to get a good tap on. I thought about converting to electric pump to get around this issue.
01-02-2013, 12:15 PM | #17 | |
http://www.summitracing.com/search/p...ck-Off%20Plate http://www.jegs.com/webapp/wcs/store...ock-Off+Plates
01-03-2013, 10:11 AM | #18 |
If you go electric put the pump in the fuel tank (I had 4 inline pumps go out within a week on my 350TBI system) put the pump in the tank and have never looked back. This is of course a 14psi pump on a Throttle Body Engine ......getting ready to drop a LT1 in her now and will have to upgrade the fuel pump to match the needs of the tuned port injection system. Kieth
01-03-2013, 01:26 PM | #19 |
I'm a big mechanical pump guy as well. They are solid and reliable and not as finicky with bad or dirty gas. Same holds true with analog gauges as well. Keeps troubleshooting a lot more basic. My experience is that when you start getting into electric its more for performance gains, so unless your doing something that you would need the extra control over it's really unnecessary IMO. Now if you were running a more modern engine, say an LSx and you have the ability to control flow/pressure then it's very nice to have.
