Old 02-06-2003, 12:18 PM   #1
chaptr2
chaptr2's Avatar
Polyethylene fuel tank physics?
Ok this is for the people who have installed or really know the physics of the fuel tank.
Right now I'm installing the fuel lines to my already installed polyethylene tank. I'm installing a BG220HR system and have all the fuel lines and most of the fittings to make it work.
My question is about the three ports on top of the tank (feed, return, and breather). I believe they are 1/4-inch holes (really small) two by the fill tube spout and one on the far side of the tank. Is the fuel sucked up to the top of the tank or is there a specific hole I'm supposed to use for the feed line? How does the fuel at the bottom of the tank get sucked up to the fuel lines?
I tried getting a mirror inside the tank this morning, but was not successful. Does anyone have any idea on how the physics of the system work?
This is only my opinion and it is subject to change.
70 GMC Short box stepside Blown 388 Stroker
72 K/5 Blazer 350/SM465/205
chaptr2 is offline   Reply With Quote
Old 02-06-2003, 12:26 PM   #2
chaptr2
chaptr2's Avatar
This is the pump I'm using.
Old 02-06-2003, 12:32 PM   #3
chaptr2
chaptr2's Avatar
here is the way the system has to run.
Old 02-06-2003, 02:29 PM   #4
da-burb
"Ochre Ogre"
da-burb's Avatar
Fuel comes from the sending unit. Take a look at that and it will all become clear.
The things you are describing are, 1) fuel inlet (largest) 2)fuel inlet overflow return line which also lets air out as you fill up 3+4) left tank vent and right tank vent.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 02-06-2003, 03:45 PM   #5
chaptr2
chaptr2's Avatar
Thank you!! I guess if I pulled the sending unit out of the box I would have seen that. That will make getting the fittings much easier. Thanks Da-burb.
Old 02-06-2003, 09:39 PM   #6
da-burb
"Ochre Ogre"
da-burb's Avatar
Now, you might look at adding a fuel return line to your sending unit. Drill a hole and add a piece of tubing, solder it in and away you go. I have heard of people using one of the vent ports as a fuel return line. I don't know if I would feel safe doing it that way. You would be driving a flame thrower if it ever slipped off while driving. Better to take a look at a modern fuel injected vehicle's sending unit and see how they routed the return tube.
Old 02-07-2003, 04:23 AM   #7
UNCLEBOB
If the poly tank is under the truck and your going to race it I under stand you will have to make a sheetmetal cover for it. Im in that process now. good luck
68 lwb 383 solid roller,250dur, 582lift, afr 210s, 10.8 comp. edel.rpm, 750vs,1 3/4 headers turbo 400, 3500 stall,ford 9 inch 3.89 gears
UNCLEBOB is offline   Reply With Quote
Old 02-07-2003, 03:14 PM   #8
chaptr2
chaptr2's Avatar
Thanks Da-burb that is a very good idea with the return line. I spent last night looking at all the possibilities of where the return will go. I will most likely go with vent tube for a return, but I will have to drill it out to 3/8. I don't want to adapt it down, because it is only a 1/4 hole that would really restrict fuel getting back in side the tank. I won't be using any hose clamps because I want to eliminate any possible leakage. This is all AN fittings with only two standard fittings with clamps.
Thanks Uncle Bob, I didn't know that. Is there a specific cover or thickness it has to be? It will be awhile before it hits the track, but any advanced notice is appreciated.
Old 02-08-2003, 04:00 AM   #9
UNCLEBOB
I still have to ask ray the local tech guy on what gauge metal it needs to be. Ill let you know.
Old 02-08-2003, 11:49 AM   #10
chaptr2
chaptr2's Avatar
Thank you for doing that. Is there any other surprises I should be aware of?
Old 02-16-2003, 01:42 AM   #11
UNCLEBOB
Bottom of fuel cell must be covered with.024 steel or .032 aluminium sheet metal when fuel cell protrudes through floor. NHRA Rulebook
Old 02-16-2003, 02:08 AM   #12
chevymad
One more thing, on an eletric fuel pump system where the fuel is constantly flowing back to the tank via the return, the return line should exit within 2" of the bottom of the tank. Dont just dump the fuel in the top of the tank. Especially with a plastic tank. The fuel falling inside will build up a static electric charge. If it should discharge you can blow the tank up!! This is the same reason why you shouldnt fill poly gas cans in a pickup bed.. or regular gas cans on a poly bed liner!
chevymad is offline   Reply With Quote
