*Proud Member*
need help w/ a tilt column question
i'm lookin' to buy a tilt column for my truck... i have a '75, but i put an '84 cab on my frame... so, the million dollar question is, can i buy a '73-'80 tilt for it? or does it have to be an '80-84?
thanks! ![]() |
I'm back with 2nd truck!
Tough question. Not sure but this may help. If the cab itself has the cutout for the wiper controls on the bezel itself then it would be ok. If not then you either need a newer column or maybe cut out the hole for the wiper controls. Also another problem is the light switch was moved up a bit in the later years. I would look at the cab (84) and compare to the 75. I bet you have to use the newer column.
1979 Chevrolet Bonanza Big10 "Tootsie Roll" 1985 Chevrolet Silverado (wife's) Member of the Southern Bowties Club "Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Brandon pretty much covered this. All the columns will bolt in, you just need to decide ahead of time what kind of dash you plan to use, or if you want the accessories mounting on the column.
Just found this, look here too: http://67-72chevytrucks.com/vboard/s...threadid=39385
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
