Old 03-30-2010, 12:26 AM   #1
JJorgensen52
Simple? What's simple?
JJorgensen52's Avatar
Help with seriously leaky rockwell
I've been driving my truck on the highway a fair bit as of late, and aside from the fact that it vibrates a bit in the t-case (which I would expect from a gear driven case like the rockwell), when driven at speed (60 - 65mph) for any kind of time the case leaks gear oil. A considerable volume of gear oil.
That said,
1. What in particular should I be looking for in terms of leaks? It appears to be leaking both from the tranny - t-case adapter and the rear yoke retainer.
2. Are seals / gaskets still available to an extent that I can actually get this thing to stop leaking? I've been super happy with it and would rather not change it out.
CURRENT
'50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build
'63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos
'66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos
'69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!)
'72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh
'99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily)
'99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs)
SOLD
'71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder)
JJorgensen52 is offline   Reply With Quote
Old 03-30-2010, 09:43 AM   #2
sharpie1972
Re: Help with seriously leaky rockwell
Sounds like you should be able to catch both of these leaks. Neither seal is too bad to address. You'll have to drop your driveline and split the case off the adapter, but it might be worth it if it saves you adding 90 weight often. The rear yoke seal might be the place to start since all you would need to do is drop the shaft and pull the yoke. You may have a groove in the yoke that is causing some of that leak. A new one or a sleeve on the yoke with a new seal works wonders. I agree with Vectorit, nothing hums quite like a Rockwell! Sharpie
sharpie1972 is offline   Reply With Quote
Old 03-30-2010, 11:26 AM   #3
1969K10
1969K10's Avatar
sounds like you need some new seals. they should slow down the leaks, but won't stop them.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
