03-30-2010, 08:51 AM | #1 |
10 Bolt Rebuild
Hello,
My 1982 4x4 10 bolt (rear) siezed at 35mph and after pulling the rear cover the carrier was cracked and the spider gears shattered. It served me well for 265 miles. QUESTION: Is there a good DVD or video that details how to rebuild a 3rd member? Even a hard copy manual would probably work. I have done my share of SBC rebuilds and a couple of manual transmissions, but never a rear end except for axle and axle bearing/seal replacements. I assume this will be a complete rebuild, ring and pinion as well as carrier assembly. Any help will be greatly appreciated. Thanks Last edited by Geezer2; 03-30-2010 at 08:52 AM. Reason: correct content |
03-30-2010, 10:49 PM | #2 |
Re: 10 Bolt Rebuild
im pretty sure you have to have a shop put ur ring and pinion in. it needs to be indicated in perfectally. that alone costs a couple hundred bucks. im not sure bout anything else because i have about the same amount of experiance as you lol..but im no expert.. anyone else?
"I'll keep my guns, money, and freedom. You can keep the "change" |
03-30-2010, 10:56 PM | #3 |
gets board easy.......
Re: 10 Bolt Rebuild
what are your skills, Rear ends MUST be done right,
you mess up and you have a bigger problem in the end. Its not like changing your oil!! |
03-30-2010, 11:30 PM | #4 |
BMW & ASE Master Certified
Re: 10 Bolt Rebuild
ive never done it myself but with the write ups on the forums and the right tools + confidence it can be done at home. me myself when i get my hands on a posi, im doing it myself.
on the other hand if you lack one of the 2 criteria, shops charge extra (normal price) if you bring the truck in as a whole... if you bring the diff by itself, they give you a price discount... fyi clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
03-31-2010, 12:05 AM | #5 |
Re: 10 Bolt Rebuild
Thanking all for our inputs, all comments have helped. I am droppng the diff the next couple of days and will take it apart except the R/P. We'll see what things look like, I know for sure the carrier is shot. I have located a used 3rd member drum to drum so I should be back on the road fairly quick. That will give me time to take the old diff apart and smarten up. Agree, calibrating the backlash on a R/P replacement appears to be no trivial task and looks like it requires an experienced eye to adjust. That may need to be done by a pro and I will have the diff ready for bench work. However, I'm kinda inclined to take things on unless I lack special tools. Anyway if any think of something else please pass on. Thanks......
05-02-2010, 02:11 PM | #6 |
Re: 10 Bolt Rebuild
OK, I took the diff to a pro and they pressed on new carrier bearings, reinstalled the ring and pinion and checked for correct tolerances. I bought a used carrier and spider gears from them. Also installed new axle bearings and seals. I intsalled the diff and now have to fill with fluid and test. Thanks
I keep searching for the procedure to install new spider gears but cannot find anything. |
