Old 03-30-2010, 12:33 PM   #1
brossow
Amateur Rust Fighter
brossow's Avatar
Question Looking for tire size recommendations (and pics if ya got 'em)
Just ordered the Boss 338 wheels for my '72 shortbed stepside but am at a disadvantage when it comes to actually sizing up the proper tires because the chassis is in my garage but the bed is in another town in my buddy's body shop and therefore I can't measure as I would like. Hoping someone else with a similar stepside can tell me what they're running so I can get tires ordered before the truck is actually back together. The truck will have about a 4/6 static drop with leaf springs out back.
Here are the wheel specs:
Front: 20x8.5, 20 mm offset, 5.239" backspacing
Rear: 20x10, 20 mm offset, 6.225" backspacing
Rear
I'm planning to run a 1" adapter (spacer) on the rear, effectively making the backspacing 5.225".
I want the biggest tire I can fit out back without even a chance of rubbing. I had been thinking 295/35 or 295/40 but there don't seem to be many options in those sizes, and price is important. At about 3/4" narrower, would a 275/35 be too narrow on this rim?
Front
95% sure I'm going 245/40 up front. Any reason not to?
Thanks in advance for any advice!
Brent
Brent
'72 Chevy SWB stepside - [ Build Thread ]
'79 ChevMC SWB fleetside - [ Build Thread ]
'64 Chevy SWB fleetside & '66 Chevy SWB stepside (waiting in the wings...)
brossow is offline   Reply With Quote
Old 03-30-2010, 05:35 PM   #2
Boyd
Resident Lurker
Boyd's Avatar
Re: Looking for tire size recommendations (and pics if ya got 'em)
brossow - I ordered a 338 staggered set of 20's for my '72 step also. I also want to run a 245/45f and 295/40r, but like you; I also have had a hard time finding a 295/40 for the rear. I don't have any advice other than I will let you know if/when I find a set since we want/have similar set ups.
Boyd is offline   Reply With Quote
Old 03-30-2010, 06:18 PM   #3
jugernot
Life, Be In It.....
jugernot's Avatar
I also have a step side and will be using the same wheels/sizes. I measured the wheel well at 11.5 inches and the 295 shows as 11.61 inches wide. So I think I will use a 285 40 20. I used this site to help determine tire height and width. I have not done alot of searching for this above mentioned tire size. I would like to know what you find out.
http://www.wallaceracing.com/tire-aspect-calc.php
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows"
http://67-72chevytrucks.com/vboard/s...d.php?t=200082
jugernot is offline   Reply With Quote
Old 03-30-2010, 06:27 PM   #4
Boyd
Resident Lurker
Boyd's Avatar
Here is another good site for tire size calculations. I like it because it will let you compare two different sizes at a time and it tells you the rotational differences.
http://www.miata.net/garage/tirecalc.html
Old 03-30-2010, 07:46 PM   #5
57larry
I got 255-70x15 all the way around on my 72
57larry is offline   Reply With Quote
Old 03-30-2010, 08:58 PM   #6
lolife99
67-72 parts collector,…
lolife99's Avatar
245/40 and 295/40.
Look at BFG's KDW's, Toyo Proxie II's, or Firestone Firehawks.
Keith
Convert to disc brakes.
Old 03-31-2010, 02:20 PM   #7
72BlckButy
Tot Roddin'
72BlckButy's Avatar
245/40 and 295/40.
x2
Only thing you will have to change from lolife's post is that the Toyo's are only available with a 255/40 not a 245/40; but that will also work on the front of your truck. Trying to find matching tires in a 245/40 or 255/40 and a 295/40 is getting more difficult each day.
This is the prime tire setup IMO.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 03-31-2010, 06:36 PM   #8
Boyd
Resident Lurker
Boyd's Avatar
Can only find a 295/40 in a Toyo Proxes II, but they do have a 295/45. It's sidewall is 1.2" taller, which is a good thing in my book. Adds a little "rake".
Old 04-01-2010, 02:18 PM   #9
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Boyd... I would compare some trucks that are running a 295/45 (big al) and a 295/40 (lolife99, n2trux, etc.) and see the difference, as it's pretty substantial.
-Nate
Old 04-01-2010, 02:57 PM   #10
dougminton
dougminton's Avatar
falken 305/50r20 on a 10" wheel on the back and it clears the bed by 1/4" sorry dont remember front size backspacing about an inch less than yours.
The TEAL GMC build thread is HERE
1972 GMC SWB
454 oval ports
TH400
fastest 1/4 mile time so far
13.05 @ 104
If you think you have too much horsepower
you obviously have a traction problem !
dougminton is offline   Reply With Quote
Old 04-01-2010, 10:28 PM   #11
hemihead
hemihead's Avatar
I got these sizes in Toyo, about the only tire avaiable in these sizes.
1967 SWB C-10, BBC 454, T400, 3.73 posi, 20" Coys
1972 K5 Blazer, SBC 400, 4 spd, 3.73, 6" lift, 35" mud grapplers
2011 Sierra Denali HD, 6.6 L Duramax, RBP 96R rims, leveled and Nitto trail grapplers,
2009 Acura MDX
hemihead is offline   Reply With Quote
recommendations, stepside, tire size
