Old 03-30-2010, 01:13 PM   #1
Oklahoma
Airconditioning
Getting ready to order a vintage air set-up any comments on do's and dont's would be appreciated.
Oklahoma is offline   Reply With Quote
Old 03-30-2010, 06:47 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Airconditioning
Here's an older thread, which includes a link near the bottom to another related thread which may provide some interest:
http://67-72chevytrucks.com/vboard/s...ht=vintage+air
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 03-30-2010, 06:52 PM   #3
Scottshotrods
Re: Airconditioning
If you have not ordered yet give us a call or e-mail we have some great
deals on Vintage Air
justin
(805)485-0382
justin@scottshotrods.com
Scottshotrods is offline   Reply With Quote
Old 03-30-2010, 08:28 PM   #4
tommys66
Re: Airconditioning
do a search for COOLAIR. He installed a GEN II compact system. looked like it fit well.
I love the smell of lead paint!
tommys66 is offline   Reply With Quote
Old 03-30-2010, 10:34 PM   #5
Scottshotrods
Re: Airconditioning
The one you want to get is Vintage Air 100% they stand behind there product
they can ship out same day most of the time and they have direct bolt in units that anybody can put in.
If you guys send me a e-mail justin@scottshotrods.com with your contac info
I will call you back same day and give you all great prices and service.
Justin
www.scottshotrods.com
Old 03-30-2010, 11:15 PM   #6
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Re: Airconditioning
Justin
looking for a quote
h4zed77@yahoo.com
Sick5 is offline   Reply With Quote
Old 03-30-2010, 11:18 PM   #7
Scottshotrods
Re: Airconditioning
Originally Posted by Sick5 View Post
looking for a quote
h4zed77@yahoo.com
Send me over what you are looking for I will have prices for you on wed am
Justin
Old 03-30-2010, 11:25 PM   #8
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Re: Airconditioning
Justin
1965 gmc air and heat vintageair
Old 03-30-2010, 11:31 PM   #9
Scottshotrods
Re: Airconditioning
I will have a total for you on wed if you can send me a e-mail so
I can send you over some prices for you on wed and are you looking
for a 100% complete kit let me know in a e-mail if that is possible.
Old 03-30-2010, 11:33 PM   #10
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Re: Airconditioning
no problem will do
Old 03-31-2010, 10:52 AM   #11
coolair
Re: Airconditioning
The Sure-Fit for the 60-66 trucks are for Chevrolet only as the GMC dash is different. I put a GEN II Compac in my 65 Chevy - it's a little more work/fabrication but in my opinion, it's worth it to get an all electric operated evaporator vs a vacuum system.
Let me know if you have any questions - Mark @ VA 1.800.862.6658 ext.111
coolair is offline   Reply With Quote
Old 03-31-2010, 12:05 PM   #12
DaddyMack
Wide Eyed User
DaddyMack's Avatar
Re: Airconditioning
I have Vintage Air, and I believe mine is all electric. Make sure you upgrade your Alt. I have a 155 amp alt and with the stuff I am running (not just the air) i could prob use a 200. Just switching from Med fan air to Hi air it drops my charging .7 at idle and about .3 running.
I have to say that I am not sure if mine was specifically for my truck, so my comments may be off...
things that I would like to see diff:
I would like two seperate outlets for the defroster rather than having to use a Y connector. The air movement for the defroster is a bit weak IMO (see comments below).
Also, It seems the controls are a bit cheesy. I already broke a selecter knob almost immediately and had to replace the entire head unit. Luckily they are only like $40.00 and luckily SoCal parts had one in stock (maybe that's why they are only $40). I barely touch them now to change the settings in fear of breaking another knob. I like the head unit from Dakota Digital but the price is almost as much as my entire gauge package was from them.
Last, I would like to see a bit more air movement on high, as I only have three vents for the a/c and if I didn't have a single cab, it would be hurtin. I haven't been through a summer yet, so I can't tell if it's gonna hold up at 110. I have only had it going when it's been 80.
With this being said, I am not sure any aftermarket a/c system is going to be great, but I haven't tried any other. For the price they should be.
you can see head unit...
as it was being installed...
1962 Chevy P/U SB Fleetside
350/350
2.5/5 static drop
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=294723
Final (as final can be ) Pics: http://67-72chevytrucks.com/vboard/s...d.php?t=393441
DaddyMack is offline   Reply With Quote
Old 03-31-2010, 02:19 PM   #13
coolair
Re: Airconditioning
DaddyMac - Just read your post and was confused about something - you have a Gen II Compac - it has two defroster outlets not one so you shouldn't need to Y the defrost duct hose. The Compac should have more than enough air flow - last summer in San Antonio we had 65+ days over 100 with high humidity and I ran mine on medium fan speed 90% of the time and was more than comfortable and the wife was too cold every-time she rode in it.
Make sure your duct hose is pulled as tight as possible to aid in air flow, also the rectangle vents are more restrictive than the round ones - I normally recommend a round vent in the corners and the rectangle in the middle. Also check the blower motor and that you have 3 distinctive speeds.
You should see 35-40 degree vent temp out of the vents - so if you insulated your cab well, you should have no problem cooling your truck in Vegas.
Let me know if you have any questions.
Mark
Tech Support
Vintage Air
Old 03-31-2010, 04:03 PM   #14
DaddyMack
Wide Eyed User
DaddyMack's Avatar
Re: Airconditioning
Mark
Tech Support
Vintage Air
Thanks Mark... I will pull it down and take a look this weekend if I have time. It may simply be blocked. I will double check. I will check the temp at the vents as well and I do have three speeds.
350/350
2.5/5 static drop
Old 03-31-2010, 08:52 PM   #15
DWC
DWC's Avatar
Re: Airconditioning
Hey Mark, would a system like this cool a Suburban or would I need some sort of rear unit too?
DWC is offline   Reply With Quote
Old 03-31-2010, 08:56 PM   #16
protrash64
Resistance is Futile
protrash64's Avatar
Re: Airconditioning
I have an old 'knee freezer' in my 'burb and it wouldn't come close to keeping up with summer down here. When I re-do it I will add a second blower in the rear area.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 04-01-2010, 11:14 AM   #17
coolair
Re: Airconditioning
DWC,
My first question would be how are you using the Sub? Are you going to have passengers all the way in the rear or just the front half of the truck?
Without knowing the answer to the above question - I would recommend doing more of a Custom system rather than the Sure-Fit. I would look @ the Gen IV Magnum evaporator - this is our highest output system designed for large sedans and wagons plus it has the latest electronics to operate the doors and control the temp so it operates like a late model OEM system. We can use some of the items from the SFK to aid in install such as the defrost duct adapters, condenser kit, firewall block-off, etc.
I think the Gen IV Magnum by itself, will work fine as long as you have the truck well insulated. You can always add a rear evaporator later if needed - it may be a little more hassle but if one evaporator is sufficient, it would be a lot cheaper.
Mark
Old 04-02-2010, 08:24 AM   #18
Oklahoma
Re: Airconditioning
Coolair, I have been talking to a local shop that is suppose to order the ac unit for my 62, but have been having problems with them getting back to me, and that pisses me off, treating a potential buyer like this is unacaptable. So I will get a quote from you.
I have a 62 chevy with a 350 with a newer style serpeinteeen belt set up out of a 93 chevy truck. I was told by these guys that I would need an adapter for the ac that will come in the kit, also that I would not be able to get the electronic control head unit, is this true? If I have time today I would like to talk to you directly if this is possible give me your # so we can talk.
Derek.
Old 04-06-2010, 03:50 PM   #19
Hart_Rod
Hart_Rod's Avatar
Re: Airconditioning
Justin
Email and pm sent.
Hart_Rod is offline   Reply With Quote
Old 04-07-2010, 06:23 PM   #20
Oklahoma
Re: Airconditioning
Well I just ordered my ac from Mark (coolair on here) at vintage air, he couldn't have been more heplful with the process of what I need, BIG thanks Mark.
Old 04-13-2010, 07:14 AM   #21
Oklahoma
Re: Airconditioning
Well I got my Vintage Air unit in yesterday and took it all out to look it over, to make sure nothing got damaged in shipping, boy it sure looks intimidating, but I'm sure it isn't anything that I cant handle.
Old 04-13-2010, 06:04 PM   #22
protrash64
protrash64's Avatar
Re: Airconditioning
Nice!! You should post up pics of the install if you get achance to take them. I'd be interested in how it all goes in.
Old 04-13-2010, 06:56 PM   #23
DWC
DWC's Avatar
Re: Airconditioning
x2
Old 04-13-2010, 07:21 PM   #24
Togart
Togart's Avatar
Re: Airconditioning
x3
Togart
Togart is offline   Reply With Quote
Old 04-14-2010, 08:43 AM   #25
Oklahoma
Re: Airconditioning
I took pic's of the it after the removal of the old heater system, and will post them when I get a chance. I was wondering if there is a market for the old heater system? I'm not trying to sell on here, just wondering if it is worth keeping or trying to sell on ebay. I wont throw in the scrap pile, because as sure as i get rid of it, someone or my self will need it, that's usually the way it works
