03-30-2010, 02:21 PM | #1 |
Prop Valve pic please
I am in the process of putting `72 disc brakes on my `70. I need a pic of the proper way the lines run from the master cyl to the valve and which lines go where (front and back) from the prop valve. I'm pretty sure I have it right but don't want to bend lines until I'm sure. I know alot of you guys have done this. Thanks
03-30-2010, 02:27 PM | #2 |
Tot Roddin'
Re: Prop Valve pic please
Beuford, check out the install of my proportioning valve in my build thread in my signature (Blank Slate). There's a ton of pics of the setup in the thread. Hope this helps you out.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
03-30-2010, 02:51 PM | #3 |
member #16
Do you have a C/10 or C/20? The lines are different.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
03-30-2010, 02:58 PM | #4 |
Thanks alot. I printed the pic out so I don't have a senior moment and have to log back on to look again. I bought a new master cyl but I got the prop valve and center link and rotors from a donor truck. But they were off the truck already and I never saw how the lines were run. The rear line is for the front brakes right? Thank blkbeauty.
Bob |
03-30-2010, 03:10 PM | #5 |
member #16
Bob the rear line is for the front brakes on a c/20 opposite on a c/10
03-30-2010, 04:17 PM | #6 |
Thanks john. It is a C20.
03-31-2010, 02:06 PM | #7 |
Tot Roddin'
Sorry about that Bob... wasn't aware it was a C20, but I'm glad to hear you got it figured out.
