Old 03-30-2010, 05:29 PM   #1
chevroletrestoguy
brass junction block on the rear end
Guys, I have a 65 truck that has a 70 rear end in it that I am restoring. Evidently it didn't have the right brass block on it to start with, cause the block is square and the hole on the tab on the rear axle tube is round. I have a block off of a 63 rear end and it comes closer to fitting the tab, but not quite. I guess I could grind the hole to make it fit, but my questions are:
What brake hose should I order to use with a 65 frame and 70 rear end (with a 63 brass junction block)???? Or does anyone sell the brass junction block for the 70 rear end?
chevroletrestoguy is offline   Reply With Quote
Old 03-31-2010, 07:48 AM   #2
dwaite72lnghrn
Re: brass junction block on the rear end
On my '72 the brass block is part of the flex hose from the frame to the rear differential.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 03-31-2010, 10:25 PM   #3
chevroletrestoguy
So the metal clip connects to the hose then, correct?
Old 04-01-2010, 07:19 AM   #4
dwaite72lnghrn
The square block bolts to the axle housing and the round end clips onto the hanger on the frame cross member.
This is the '72 longhorn attachment.
The rear brake lines connect to the two holes in the square block.
2009 HHR aqua blue
Dave & Jeanne
Old 04-01-2010, 08:44 AM   #5
chevroletrestoguy
Thank you for the picture. Yeah, that is definitely different from what I have. The block is a separate piece that the axle lines screw into and then the hose somehow screws into it as well. It is clipped to the axle housing by a tab with a round hole in it. I took pictures during disassembly, just not real good ones.
Old 04-01-2010, 08:50 AM   #6
Sinister
Between Trucks...
Sinister's Avatar
My '69 3/4 ton is like that. Might try a WTB on the Parts Board.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 04-01-2010, 01:09 PM   #7
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
We have new ones in stock. I just need to find my camera so I can take a picture to show you. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 04-04-2010, 09:53 PM   #8
chevroletrestoguy
Here's what it actually looked like when I got it back together. I am going to have to enlarge the hole on the frame for this 1970 hose to fit.
