Rusty Rockerfeller
![]() Join Date: May 2003
72 Chevy one ton single rear with disc brakes??
about to pick up a rolling frame from a 72 chevy 4x4 truck. it is 8 lug and has the one ton style rear end with the front loaded chunk and also has disc brakes.it is 8 lug and im getting the 4 speed and transfer case as well.is this a one ton or 3/4 ton? ill probably try and sell it but just want to figure out what it is. thanks
Re: 72 Chevy one ton single rear with disc brakes??
Well,there were no factory K/30s.It could be a C/30 Napco conversion.Most likely a K/20 and some HO52s had the pre-load set on them.Only the brakes and bearings vary between HO52 and HO72...other than the pre-load.
#3 | |
I have a radical idea!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
Rear disc brakes were probably onstalled as a cheaper alternative to buying drums for these rear ends. Discs are all later model stuff with 14 bolt brackets.
Rusty Rockerfeller
The front has the disc brakes, not the rear. Sorry about that
It is a 3/4 ton. Front discs were standard starting in '71.
Tim |
