Old 03-30-2010, 08:07 PM   #1
palposity
palposity's Avatar
HELP! Need Advice! 86 K20 Changing Axle Shaft
Hey Guys,
I have a K20 w/ a 10 Bolt front axle. While I was plowing snow recently the driver side U-Joint gave out and the yokes of both the inner axle and outer stub shaft tore themselves to shreds. I have been trying to get the axle out, but I'm having trouble getting the knuckle off. I have removed the tie rod, the drag link, and I got the upper ball joint nut off, but I can't quite figure out how to free up the lower ball joint nut (remains of yokes in the way), then how do I press it out with the remains of the axle yokes in the way? Anyone have pics of this procedure?
Any advice would be appreciated. And yes....I know...take better care of my U-Joints in the future.
Project #1 "Pops"--1980 Chevrolet Scottsdale C10 3rd Generation in the same original owner family. GOAL: Restore to "almost" original.
View Project Pops HERE
Project #2 "Cletus"--1986 Chevy K20 4.10 Gear Ratio GOAL: Restore into a heavy duty work/plow rig
View Project Cletus HERE - SOLD
DD--2008 Duramax CCSB
palposity is offline   Reply With Quote
Old 03-30-2010, 08:23 PM   #2
Rollinsqrbdy
Rollinsqrbdy's Avatar
Re: HELP! Need Advice! 86 K20 Changing Axle Shaft
I dont have an answer but, if you go onto you tube and type in ur problem theirs videos on how to take em apart and fix em. Its pretty cool.
Its Kool to be a square
2013 Chevy Silverado Z71 w/ 7" lift and 35" Nitto's
1985 C-10 ......My dream truck (under construction)
1984 k 10 Silverado...6" lift with 38.5 super swampers
New Mexico Member
--- Member of the Square Body Club---
Rollinsqrbdy is offline   Reply With Quote
Old 03-30-2010, 09:17 PM   #3
palposity
palposity's Avatar
Yeah...I looked on youtube without much luck for my specific procedure.
Old 03-30-2010, 09:58 PM   #4
85burb
85burb's Avatar
If you take your brakes off and rotor off there should be a set of bolts holding the spindel to the knuckel. Take them out. Then take the spindle off then you can remove the inner shaft if not you have to remove the front cover and take the c clip off the shaft. then you can get to the nut. Also if you go to autozone.com they have a online repair guide with pretty good pic.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 03-30-2010, 10:21 PM   #5
palposity
palposity's Avatar
Thanks. I took the C-Clip and WARN hub cover off (as well as the caliper), but it looked like the rotor was a single unit w/ the spindle knuckle assembly. Maybe I just need to give the rotor a couple of taps with a hammer to jar it lose then?
Old 03-31-2010, 01:23 AM   #6
85burb
85burb's Avatar
There should be a nut of some kind in there. You may or maynot need a fancy socket to get the nut off. But if you have the bearings out the hub/rotor should slide off with minor effert. Autozone.com has a diagram of all the crap in the hub. http://www.autozone.com/autozone/rep...00c1528004c663
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 03-31-2010, 09:29 AM   #7
James McClure
One shot, one kill.
Pal, wish I was closer to you, I've done hundreds of front axels over the years. I'm not sure if I could walk you thru this without missing something because I'm so used to them. You can call me if you wish and I'll do my best. My number is 518-581-1622. If you want I'll call you, I have the unlimited cable phone thing with roadrunner. My e-mail is "jmcclur2@nycap.rr.com" if you don't want to post your number here. Jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
Old 04-02-2010, 02:48 PM   #8
palposity
palposity's Avatar
Thanks for all the offers to help. I finally was able to get the axle out last night. I am all set!
