Old 03-30-2010, 08:48 PM   #1
Aaron104
pulley bolts
i have a 1970 chevy p/u with a 5.7 350 and i wanted to know if ne one knew what bolts to get for the pulleys. i mixed them up on accident and dont want to get it wrong. what are the sizes of bolts and threads of all of them except the power steering for a stocker engine? thanks!
Aaron104 is offline   Reply With Quote
Old 03-30-2010, 08:53 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: pulley bolts
They are 3/8-24 threads on the crank.
Length is completely dependent on what pulleys you have. Some lower pulleys are steel and some are cast iron. They take different lengths.
Water pump pulleys are 1/4-28 thread. Again, length depends on the particular pulley you have.
Old 03-30-2010, 09:24 PM   #3
Aaron104
Re: pulley bolts
what if its just stock?
Old 03-30-2010, 09:27 PM   #4
Tx Firefighter
Re: pulley bolts
There are different stock pulleys. I have them hanging on my shop walls. Some pulleys are thicker and some thinner. Some cast iron, some stamped steel.
Old 03-30-2010, 09:54 PM   #5
jsmithbm
jsmithbm's Avatar
Re: pulley bolts
Hey Tex, is the water pump bolt a course thread?
Learning as I go!
jsmithbm is offline   Reply With Quote
Old 03-30-2010, 09:56 PM   #6
Tx Firefighter
Re: pulley bolts
Fine thread.
Old 03-30-2010, 10:38 PM   #7
Aaron104
Re: pulley bolts
oh ok thank you!
Old 03-30-2010, 10:47 PM   #8
CE20934
CE20934's Avatar
Location: Help! I'm in an office park with its own network of freeways!
Re: pulley bolts
Water pump pulley bolts should be 5/16"-24, not 1/4"-28.
'67 C20--427 tall deck/SM420, 4.10 HO52 (Michigan has not been kind to the Old Man)
'95 Caprice--355 LT1/T56/3.42 8.5" 10-bolt (daily driver, almost 300k on the chassis)
'07 Outback--wife's car. 125k & counting. No head gasket or transmission issues yet. *fingers crossed*
CE20934 is offline   Reply With Quote
