Old 03-30-2010, 08:56 PM   #1
Cap'n Hook
Workin to live...
Cap'n Hook's Avatar
Question 4x4 - Different gears front & rear?
So I've only used the 4 wheel drive once on my Jimmy in the year and a half I've owned it, but now I think it has different gears in the front and rear diffs.
I locked in the hubs and shifted to 4Lo, and drove down a mile of dirt road to my house. After about 500 feet, I noticed something didn't sound right, sounded like binding or something. So I let my wife drive a bit while I walked by the truck, and noticed both rear wheels would turn less than a quarter turn, then slide forward a bit, like they were locking up, then turn a quarter again, then lock.
The only thing I can figure is someone swapped out the rear gears and didn't change out the front with the same ratio. If the front was a 3.08 in theory, and the rear a 3.42, that may cause this? Maybe? I'm stumped!
The first time I used the 4 wheel drive I was on grass and leaves, and didn't notice this!
Jason
Cap'n Hook is offline   Reply With Quote
Old 03-30-2010, 10:30 PM   #2
AJs72K5
AJs72K5's Avatar
Re: 4x4 - Different gears front & rear?
Certainly sounds suspect. If that is the case, be glad you did it in the dirt and not on the pavement as you would have been binding up REALLY bad. You have two options that I can think of at the moment....
Get the whole truck up on jack stands (one on each corner). Put the truck in 4wd and let it idle in gear. Check if front and rear are turning equally. OR...open up both pumpkins and check the gears themselves.
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 03-31-2010, 10:13 AM   #3
Burt4x4
Burt4x4's Avatar
Ya, count the teeth on the R&P front and rear. If it's not that then your transfer case may have an issue, assuming the issue goes away when you move to 2x4?
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 03-31-2010, 10:21 AM   #4
67chevy2wd
67chevy2wd's Avatar
Another thing you could do is put it up on jack stands. Put the transfer case in neutral and spin a tire and count the revs of the tire v.s. the revs of pinion. You might have to leave one tire on each axle on the ground though if the opposite tire turns while you are trying to turn the other.
07 Chevy classic LBZ Duramax (a few mods)
'67 Chevy 1/2 ton 2wd (in pieces)
'69 Chevy 1/2 ton 2wd (on hold)
'71 GMC 3/4 ton 4x4
‘71 GMC 1/2 ton 2wd suburban
67chevy2wd is offline   Reply With Quote
Old 03-31-2010, 03:12 PM   #5
SeventyOne
This is the easiest way to figure out the ratio w/o pulling the inspection cover on the axles.
One tire revolution will equal some number below...
A little over 3 pinion revolutions = 3.08
A little less than 3.5 pinion revolutions = 3.42
You get the point
Just get some chalk for a maker and go to town!
SeventyOne is offline   Reply With Quote
