03-30-2010, 10:43 PM | #1 |
vaccuum booster with 1barrel carb
is this possible. my truck is a L6 with 1 barrel carb. 250ci. the truck has disk brakes but i'm looking to upgrade to power disk near future. i'm going to get a kit that has drop spindles. so, can a 1 barrel carb produce enough vaccuum to operate a power brake system?
1968 Chevy C10 swb fleetside 2005 Chevy Silverado crew cab (SS) 1977 Goldwing cafe racer 1977 Chevy nova (first car/ first love) |
03-30-2010, 11:08 PM | #2 |
Re: vaccuum booster with 1barrel carb
The engine makes the vacume, need to find or install another vacume port somewhere.
03-30-2010, 11:25 PM | #3 |
Truck and auto performance nut
find or make (drill and tap) a port in the intake manifold?
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
03-30-2010, 11:34 PM | #4 |
Very possible as they said. I had power discs on my 68 w/a 250/3spd.
03-31-2010, 06:37 AM | #5 |
Watch out for your cornhole !
Every inline 6 I have ever seen had a fitting on the intake manifold below where the carb mounts just for the brake vacuum fitting. GM sold them with power brake option forever. You're good to go.
03-31-2010, 12:51 PM | #6 |
but was it vaccuum booster or was it hydroboost?
03-31-2010, 12:53 PM | #7 |
but was it vaccuum booster or was it hydrobooster
03-31-2010, 12:53 PM | #8 |
Vacuum. They even made special offset air cleaners so it would clear the brake booster.
Here is my old truck with one on it.
03-31-2010, 12:54 PM | #9 |
i will double check the area when i get off work today. thanks
03-31-2010, 06:17 PM | #10 |
Vacuum boost w/discs all swapped over. I couldn't find the offset air cleaner like TxFirefighter had so I used a smaller aftermarket set-up for a 1-barrel carb.
03-31-2010, 09:25 PM | #11 |
i looked at mine awhile ago and couldn't come up with a vaccuum source, yet. i did however find lots of leaks. s#!t. can someone post a side picture of their L6 so i can see the area they are using?
1968 Chevy C10 swb fleetside 2005 Chevy Silverado crew cab (SS) 1977 Goldwing cafe racer 1977 Chevy nova (first car/ first love) Last edited by primetime; 03-31-2010 at 10:06 PM. |
04-01-2010, 12:30 AM | #12 |
Picture of my 292 , I think the power power was added .
1967 Suburban 292 3spd 1964 Chevy II wagon 1971 Monte Carlo 402BB 1964 Cadillac series 62 2dr 1964 Bonneville 2dr/ht 1967 GTO 1978 Chevy Van 30 1989 R30 Crew Dually Bonus Cab |
04-01-2010, 10:22 AM | #13 |
wow. you just made my engine look like garbage. one day it will be nice as yours though.
04-01-2010, 11:29 PM | #14 |
Thanks . it's a "spray can rebuild" I took the manifolds off to replace the gaskets and thought I would sandblast and paint them while off... then had to clean the block and paint that...took off valve cover sandblast and paint, all with spray cans .one thing just led to another. Found the air cleaner at local pick n pull more spray can paint . Here's the before
04-02-2010, 03:40 AM | #15 |
Shlong Bed Club
old setup...
"If it ain't broke, hit it with a hammer, then fix it.." |
