Old 03-30-2010, 11:28 PM   #1
OffroadZ71
OffroadZ71's Avatar
OBS Suburban Steering Issues
Hey ,i have a 90 suburban with a 10 bolt front axle and recently put a lift and steering components on it. The lift is about 8" and the steering consists of a Drop pitman arm and a raised steering arm(on knuckle) and stock draglink, although i do also have a 4" dropped link,but dont use it.
Anyways onto my problems, the truck doesnt steer too far left or right. It comes no where close to hitting the stock bumpstops thats threaded into the knuckle or w/e that thing is lol. my second problem is that the tierod on the draglink hits my tire when its turned all the way to the right . I made sure to find the steering center(lock-to-lock, then half of that, which puts the steering in the right place. I have some pics to show incasee maybe theres something in there that you can spot wrong with my setup...
Lastly... i dont know if maybe a wider rim or different offset rim might be needed?? it only rubs when it turn pretty much alll the wau to the right, but a rim with less offset will make my tire stick out more, which i dont really want..as it already sits out plenty far lol
'90 Suburban
OffroadZ71 is offline   Reply With Quote
Old 06-23-2010, 05:49 PM   #2
Arin
Re: OBS Suburban Steering Issues
I'm interested in the outcome since I plan to do a similar lift soon. Smaller tires though...
Arin is offline   Reply With Quote
Old 06-23-2010, 09:18 PM   #3
OffroadZ71
OffroadZ71's Avatar
I never found out why it would rub and why it didnt turn far. im assuming its just maybe @ the limits for Push-pull steering.Crossover steering is next
'90 Suburban
Old 06-23-2010, 09:26 PM   #4
USSkoval
Your assumption is correct. Crossover is needed, along with a D60. That's just too much tire for a 10bolt, even just for street driving.
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'79 K30 Crew Cab Dually
'84 C10 Short Stepside
'88 K20 Suburban
USSkoval is offline   Reply With Quote
44's, drop pitman arm, lifted suburban, steering
