![]() Join Date: Jun 2009
I replaced the points distributor in my '72 c10 307 with a HEI distributor and when I installed my 14" aftermarket air breather on the 4 barrel carb it hits the distributor. Are there 12" air breathers and where could I get one?
Thank you. |
![]() Join Date: Mar 2010
Re: air breather
I had the same problem with mine. I threw on a 10", but I was also told that was too small. Funny too, because the 10" was bigger than the little thing that my brother-in-law had put on it before I got it. Seems to run pretty good to me. Does anyone know if it'll make a huge difference either way? The guys at the Autozone didn't seem to think so.
- '71 C10 LWB (Big Blue) ![]() - '03 Honda VTX 1300 Retro - '09 GMC Acadia (Family Car) Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=395044 |
Re: air breather
you could use the spacer like they did from the factory to raise the aircleaner for clearance issues// maybe someone has the pic to post it, i just saw it posted recently.. or maybe look in LMC catalogue and see if they offer it
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 03-31-2010 at 01:14 PM. |
Re: air breather
Your local parts store may have them. Mr. Gasket, Trans Dapt makes some. Summit has a big selection.
http://www.summitracing.com/parts/SUM-239001/ |
Re: air breather
You could use this. Its just an offset base for a 14" filter, specially made for HEI distributers. I plan on getting one of these because i've got the same problem
http://www.summitracing.com/parts/TRD-2430/
1970 c/10 swb (show truck) 1972 custom/10 deluxe 4x4 (restoration pending) 2011 silverado ecsb z71 (daily driver) |
![]() Join Date: Sep 2007
Re: air breather
all you need is a spacer that is offered from summit for like 7 dollars. it raises the air cleaner about an incha and a half if that but it clears just fine
1967custom |
