Old 01-04-2001, 11:34 PM   #1
stretch
Post ignition modules
I was just wondering how the ignition modules with different numbers of pins work differently? The 4-pin modules are pretty self-explanatory (pickup coil input, output to coil), but on the other modules there's a connector wire that goes into the cab through the firewall - why?
'71 Custom 10
350/TH350/3.73
Holley 650 Dbl. Pump, Headers, HEI
'76 K10
350/TH350/205/12-bolt(R)/Dana44(F)
Primer Gray!
'01 Grand Prix GTP - my 260 HP gas sipper!
Victory Red
stretch is offline   Reply With Quote
Old 01-05-2001, 07:32 PM   #2
sadot
Post
the two are different the 5 pin is without a computer and the 7 pin is with a computer. that is computer controled . a CCC or a C4 system
sadot is offline   Reply With Quote
Old 01-05-2001, 08:47 PM   #3
swervin ervin
You get what you pay for
swervin ervin's Avatar
Post
The 5 pin module is for distributors with the ESC (Electronic Spark Control) system. This is the one that has the wires going through the firewall.
The ESC distributor plugs into a control module behind the glove box. All the ESC does is control spark knock. You will notice the knock sensor screwed into the block in front of the starter.
I have replaced all the mess on my truck with an MSD Pro-Billet HEI distributor.
Hope this helps,
Mike
1985 Chevy C-10
Mike's 73-87 Chevy Pickup Site
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 01-06-2001, 02:10 AM   #4
Fast68Chevy
Fast68Chevy's Avatar
Post
My ESC control box is near the accelerator pedal, mounted in a free-stand-up position.
This is in the 81...
Fast68Chevy is offline   Reply With Quote
