Old 03-31-2010, 05:11 PM   #1
bigarmzz
bigarmzz's Avatar
Boss 338 wheels-anyone here got em?
found this thread on the other board, killer deals actually
http://67-72chevytrucks.com/vboard/s...d.php?t=393027
just wandering if anyone here has them on a 73-87 truck? looks like some of the 67-72 guys do, but would rather see them on one of our trucks, ya know?
thanks guys
1987 350 TBI lowered 5/7
bigarmzz is offline   Reply With Quote
Old 03-31-2010, 05:19 PM   #2
Eighty-6
Re: Boss 338 wheels-anyone here got em?
thanks guys
I have em on mine but the are 18x8 and 18x9.5. Can't up load pics till i get home though.
I found some on my system, these are a little old but not much has changed except for I put the front caps on after these pics were taken :-)
Eighty-6 is offline   Reply With Quote
Old 03-31-2010, 05:54 PM   #3
bigarmzz
bigarmzz's Avatar
looks good man, are those grey or polished? kind of hard to tell....they look polished in the one pic, but grey in the other two
thanks
Old 03-31-2010, 07:07 PM   #4
flamingbig10
6.0 powered square
flamingbig10's Avatar
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 03-31-2010, 07:11 PM   #5
tommie
97' Tahoe 2dr/2wd
tommie's Avatar
damn that's a lot of reading...
how do yours fit eighty 6?
what tires are you using?....
tommie is offline   Reply With Quote
Old 03-31-2010, 07:16 PM   #6
bigarmzz
bigarmzz's Avatar
Originally Posted by flamingbig10 View Post
man! that photochop was so cool i had to use it as my new avatar, thanks man!
i guess that pretty well seals the deal
Old 03-31-2010, 07:26 PM   #7
Eighty-6
thanks
They are chrome.
Old 03-31-2010, 07:28 PM   #8
Eighty-6
They fit great, i'll have to go look at the tire sizes. I tend to forget :-)
Old 03-31-2010, 07:57 PM   #9
Eighty-6
just looked tire size is 255\45 and 285\40
Old 03-31-2010, 08:19 PM   #10
Wild83C10
Wild83C10's Avatar
My black 18s. No engine so its sitting a bit high in the front.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 03-31-2010, 09:00 PM   #11
flamingbig10
6.0 powered square
no problem here is the website http://autowaretech10.net/nextwheels/tire_fac.htm
Aaron
Old 03-31-2010, 09:53 PM   #12
staggerd86c-10
Squarebody Aficionado
staggerd86c-10's Avatar
wild83c10, what brakes are you running on that truck?
staggerd86c-10 is offline   Reply With Quote
Old 04-02-2010, 08:25 AM   #13
Wild83C10
Wild83C10's Avatar
I have the C4 dropmember with C4 suspension stuff up front with C5 brakes. I am running a CPP disc setup in the rear.
turbo=
Old 04-02-2010, 04:42 PM   #14
Low84
Low84's Avatar
Man, I saw this thread too late or I would have placed an order
1978 stepside C10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=468265
Low84 is offline   Reply With Quote
Old 04-02-2010, 08:48 PM   #15
harnalien
TruckincrazY
harnalien's Avatar
Here's mine!
harnalien is offline   Reply With Quote
Old 04-02-2010, 08:50 PM   #16
mongoose
mongoose's Avatar
yup im in the same boat...
but im sure there will be enough interest in them to get another order together pretty quick.
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 04-02-2010, 11:24 PM   #17
chevyrestoguy
chevyrestoguy's Avatar
I have heard in the front, you have to run a wheel spacer in order to get the center cap to fit. Is this true?
chevyrestoguy is offline   Reply With Quote
Old 04-03-2010, 09:37 AM   #18
harnalien
TruckincrazY
harnalien's Avatar
not with light duty (1") rotors
Old 04-07-2010, 08:49 AM   #19
gcwhite
I read about these 1" rotors but what application did they come on? All i can find is 1.25. and do you have to change spindle too or just caliper?
1998 K3500 Crew Cab-daily driver
1987 1ton Blazer
1982 2WD Blazer
1970 C3500 dump truck
There is NO replacement for displacement!!!!
gcwhite is offline   Reply With Quote
Old 04-07-2010, 09:02 AM   #20
N2TRUX
Happy to be here
N2TRUX's Avatar
You have to change spindle and caliper. Might be a good time to upgrade....or just buy some Coys and not worry about it.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-07-2010, 09:12 AM   #21
JohnC
JohnC's Avatar
Boss redesigned the wheel due to the clearance issues with the 1-1/4" rotors so there is no need for the spacer. They supposedly have the new wheel out now. I think that is one of the reasons for the current group buy that is going on.
JohnC is offline   Reply With Quote
Old 04-07-2010, 09:16 AM   #22
gcwhite
Do you know what i could get the light duty spindle and rotors off of? I've looked in the hollander interchange books and can't find what these were used on.
1987 1ton Blazer
1982 2WD Blazer
Old 04-07-2010, 09:20 AM   #23
JohnC
JohnC's Avatar
My 84 has them. They were just a light duty suspension option. Your local parts store should have all the parts for the change if you needed it. However, since Boss has changed the wheel to accomodate the 1-1/4" rotor I wouldn't swap.
Old 04-07-2010, 09:26 AM   #24
gcwhite
Thank you. Its my understanding the 18's have not been retooled yet. I have a behind the scene access to the local auto recycler so if we have them in stock i might as well.
1987 1ton Blazer
1982 2WD Blazer
Old 04-07-2010, 07:32 PM   #25
tommie
97' Tahoe 2dr/2wd
tommie's Avatar
i read this about the 18' wheels, that they were not fixed for the 1.25" rotors yet....only the 20's....
is this true, or have both the 18's and 20's been fixed for 1.25" rotors....
(my brother wants some for his 75 w/1.25" rotors)
