Old 03-31-2010, 05:41 PM   #1
junior43
junior43's Avatar
body mount kits... should I use polyurethane or rubber???
Getting ready to replace my worn out mounts and was wondering if there were any drawbacks on using polyurethane kits?
junior43 is offline   Reply With Quote
Old 03-31-2010, 06:56 PM   #2
Otsa580
I Love Rusty Chevys
Otsa580's Avatar
Re: body mount kits... should I use polyurethane or rubber???
Quote from VTblazer
The stock rubber style is going to ride a bit softer but will flex more when wheeling.
Thread where I found it:
http://67-72chevytrucks.com/vboard/s...y+mount+rubber
1969 K5 Blazer
1997 1500 Silverado Ext Cab Z71
2010 1500 Silverado Ext Cab Z71
Otsa580 is offline   Reply With Quote
Old 03-31-2010, 07:11 PM   #3
swyfor5
swyfor5's Avatar
Got the new poly kit sitting here ready to go in myself.
swyfor5 is offline   Reply With Quote
Old 03-31-2010, 07:51 PM   #4
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
I'd go rubber, but I don't wheel my truck so I want it as smooth as I can get. If I were building something to go off-road, I'd probably go poly. I have heard that if you don't lube the poly mounts properly, they can squeak.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 03-31-2010, 09:56 PM   #5
lks dcvn
lks dcvn's Avatar
poly are also smaller than the rubber mounts so you will likely need to shim to get everything lined up again...
lks dcvn is offline   Reply With Quote
