03-31-2010, 05:56 PM | #1 |
283 Heads
I am rebuilding a 283 from a '63 Pontiac for my '61 GMC and plan to install a 700R4 along with it. The rear gear is 3.90. I need to rebuild or replace my heads. I would rather replace as it will probably be cheaper to buy new than rebuild the old. And also I could then get heads with the bolt holes in the front so I can install the alt and power steering set up from a 305/350. What heads should I use????
03-31-2010, 06:19 PM | #2 | |
Re: 283 Heads
-Chris |
03-31-2010, 06:26 PM | #3 |
Re: 283 Heads
Yes it is a Canadian 283. What is the difference. Isn't a 283 a 283?
What heads are best for this motor combo? |
03-31-2010, 06:36 PM | #4 |
Re: 283 Heads
03-31-2010, 06:44 PM | #5 |
Re: 283 Heads
My mistake, I thought you meant that a Canadian Pontiac 283 was different from a US 283. Sorry for the confusion.
Peter |
03-31-2010, 07:09 PM | #6 |
"Where were you in '62?"
Re: 283 Heads
Cammel Hump Heads! The famed camel-hump (or fuelie) heads used until '68 had no accessory bolt-holes and used 1.94 or 2.02 intake valves, depending on application. Most camel-hump heads had the 1.94 intake valves. Small Block Chevy Engine Block Identification 1Bad62Pro/Street http://67-72chevytrucks.com/vboard/s...d.php?t=353538 Small Block Chevy Cylinder Head Identification 1Bad62Pro/Street http://67-72chevytrucks.com/vboard/s...d.php?t=353542 The History Of The Chevy Small-Block Motor 1Bad62Pro/Street http://67-72chevytrucks.com/vboard/s...d.php?t=354680
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. Last edited by 1Bad62Pro/Street; 03-31-2010 at 08:18 PM. |
03-31-2010, 08:40 PM | #7 |
Resistance is Futile
Re: 283 Heads
The heads can be drilled for the accessory bolt holes.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
04-01-2010, 09:52 AM | #8 |
Re: 283 Heads
There are brackets to add PS that you can use if you don't want to drill the heads. I guess alot depends on how you are going to use the truck/motor. IMO the 283 is a good little cruisin motor, but if you are looking for some serious HP, it could be done, but your $$ would be better spent with a 350. If you do go with those heads, make sure that you get the valve seats hardened.
04-01-2010, 09:34 PM | #9 | |
Re: 283 Heads
The '416 or '601 (last 3 digits of casting number) 305 HO heads have 58cc chambers, 1.84 intake valves and flow very close to the old '461 Double Hump heads. They also have hardened seats and accessory bolt holes, great heads for a 283. Last edited by Winola73; 04-01-2010 at 09:34 PM. |
04-02-2010, 05:48 AM | #10 |
Re: 283 Heads
Thanks guys for all the info.
Peter |
04-02-2010, 09:35 AM | #11 |
Re: 283 Heads
The '416 or '601 (last 3 digits of casting number) 305 HO heads have 58cc chambers, 1.84 intake valves and flow very close to the old '461 Double Hump heads. They also have hardened seats and accessory bolt holes, great heads for a 283.[/QUOTE]
That's good info to have. |
