Old 03-31-2010, 09:46 PM   #1
nickp51chevy
Registered Chevy Owner
nickp51chevy's Avatar
D44 ?
I need to replace the seal on the axle shaft that the axle comes out of. How do I take the axle out of the shaft? (I hope those are the right terms.)
I'm looking for diagrams or step by step instructions or something that will help me with disassembly.
I think that I might have an idea how to do it but I just don't know for sure.
Thanks for the help.
Love is fleeting, but Chevy trucks are forever!!!!
1970 Chevy CST C10 long box 350/400
2008 Chevy Silverado short box 4x4
Had;
1951 Chevy short box 307/T5
1988 Chevy shot box 4x4 350/350
1971 Chevy C10 long box 4x4 350/350
1971 Chevy C20 long box 350/350
1971 Chevy C10 long box 350/350
nickp51chevy is offline   Reply With Quote
Old 03-31-2010, 11:15 PM   #2
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
Re: D44 ?
Check this out: http://www.greatlakes4x4.com/showthread.php?t=58134
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 03-31-2010, 11:28 PM   #3
nickp51chevy
Re: D44 ?
Awesome! So if I understand it correctly; there is no "C" washer (?) inside the diff that I need to take out like in the rear end. The axle just comes out without opening the diff?
Had;
Old 03-31-2010, 11:45 PM   #4
onlyifihadachevy
Re: D44 ?
yup, there shouldn't be any c clips.
72 gmc 2500 2wd drive convert
My 72 thread
http://67-72chevytrucks.com/vboard/s...d.php?t=346712
THe other truck, wheeler 69 1/2 4x4, yellow and rusty.
http://67-72chevytrucks.com/vboard/s...d.php?t=350300
onlyifihadachevy is offline   Reply With Quote
Old 03-31-2010, 11:57 PM   #5
nickp51chevy
Re: D44 ?
Cool, thanks guys.
Had;
Old 04-01-2010, 06:15 AM   #6
LONGHAIR
Re: D44 ?
Originally Posted by nickp51chevy View Post
.... like in the rear end.
This leads me to think that you are talking about the front axle? If so, it's not "that easy" to do what you are asking about.
Yes, the axle shaft will indeed come out w/o taking the cover off......but, that alone is not going to get you to that seal. The front axle seal is just behind the carrier bearing, inside the front cover. So, both axles have to come out and the carrier has to come out too. Then the seals can be removed and replaced. Then it all goes back together the same way it came apart. Be sure to mark the carrier caps before you remove them.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 04-01-2010, 08:35 AM   #7
Chevy1TonFun
Grease Monkey
Re: D44 ?
Here is another how do (all the way down and back together): http://www.off-road.com/trucks4x4/ar....jsp?id=198397
Old 04-08-2010, 07:54 PM   #8
nickp51chevy
Re: D44 ?
Are the axle seals inside the axle tubes next to the carrier?
Had;
Old 04-08-2010, 08:19 PM   #9
onlyifihadachevy
Re: D44 ?
yup, and like longhair said you will need to take the carrier out also to replace the seals, which is the reason they never really get replaced.
My 72 thread
Old 04-08-2010, 08:27 PM   #10
nickp51chevy
Re: D44 ?
I forgot that he said that. guess I'm just getting frustrated with the axle.
Had;
Old 04-09-2010, 06:12 AM   #11
LONGHAIR
Re: D44 ?
That's a "fairly" good explanation w/pictures....but ignore that comment about checking the gear pattern. You cannot go messing around with the contact pattern of used gears.
Old 04-10-2010, 02:01 AM   #12
nickp51chevy
Re: D44 ?
I got the seals in, and it only took 3 trips to Napa to get the right ones. Ya, this wasn't an easy thing like I thought it might me.
I know now that there are the seals by the carrier, but should there be some sort of a seal at the end of the axle housing where the axle shaft comes out at the knuckle? Someone had put one there on both sides. Do you think that the P/O just didn't know where they were suppose to go?
Thanks guys.
Had;
Old 04-10-2010, 09:19 AM   #13
LONGHAIR
Re: D44 ?
No, there is not supposed to be a seal there, but there is at least one company that makes one to fit.
The end of the housing is not machined to receive a metal press-in type seal like the inner. So these "special" seals are a pretty wide metal block with O-rings to seal the outer part to the "rough" housing. They are not "necessary" for 99% of trucks...extreme off roaders who deal with a lot of water/mud like them to keep the muck out of the tubes.
Old 04-10-2010, 11:58 AM   #14
nickp51chevy
Re: D44 ?
Thanks for the info guys. I'm going to be putting the gear oil back in it today and see what happens.
Had;
