Old 03-31-2010, 09:51 PM   #1
menace121978
menace121978's Avatar
Question LSx conversion radiator?
does anyone know of a radiator for our trucks with the inlet/outlet, tranny cooler lines, and steam vent all on the passenger side. i've been searching for a direct replacement/custom made aluminum one with efans and havent had any luck yet... ron davis radiators said they could make one but the cooler lines would have to be on the driverside. whats the point of that @ $1100!
any suggestions or other options im missing here?
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 03-31-2010, 10:41 PM   #2
Cherub
Cherub's Avatar
Re: LSx conversion radiator?
why are you wanting everything on one side?
Cherub is offline   Reply With Quote
Old 03-31-2010, 10:46 PM   #3
menace121978
just for a cleaner look... the water pump on the 6.0 points that way rather than running the long hose all the way to the other side. whatcha thinking? just get the stock one and run the hose??
"Dennis the Menace"
Old 03-31-2010, 11:23 PM   #4
Pyrotechnic
Pyrotechnic's Avatar
I've read that you can also take the water pump, heat the housing where the neck is pressed in, then stick something in the neck and turn it to the angle you want.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 04-01-2010, 12:23 AM   #5
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
in my swap, i used a stock 454 radiator. as far as the vent/steam port, i went to ACE hardware and got a 3/4 nylon pipe thread adapter to 1/4 or so barb fitting. and just hose clamed everything with facotry black clamps... looks plain and almost factory like.
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 04-01-2010, 08:06 AM   #6
78-5.3
78-5.3's Avatar
i used my stock diesel rad had to reduce the top hose outlet on the radiator using an adapter i used a 2002 truck top rad hose and modified the lower rad hose ,I see S&P likes the hoses on the same side but it seamed to interfer with the K&N filter on my truck
78 C-10 5.3 LSX -4L60E
78-5.3 is offline   Reply With Quote
Old 04-01-2010, 08:42 AM   #7
Cherub
Cherub's Avatar
gotcha i think that the S&P 77 ls1 swap used a radiator like your mentioning.
Just looked and the trans cooler lines are on the driverside also.
Old 04-01-2010, 09:28 AM   #8
Ceeten
Honestly, I would skip the cooler in the radiator all together and get a good stand alone trans cooler, and mount it behind the grill. That's how I did my 86, worked great!
Ceeten is offline   Reply With Quote
Old 04-01-2010, 09:33 AM   #9
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Use the stock one. Get a piece of stainless pipe to either 1] run across the top of the radiator with short sections of hose to connect it to the WP and the rad, or 2] have a piece of stainless pipe mandrel bent to make the rubber connections even shorter. Then polish the pipe. That would look pretty good.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 04-01-2010, 10:10 AM   #10
menace121978
Thata a good idea Bob. then i could always have a stock replacement radiator rather than having to have a custom one made again. hmmm...
"Dennis the Menace"
Old 04-01-2010, 10:27 AM   #11
glock35ipsc
Something like this, but polished:
I wonder if you could have just the tanks of a stock radiator ceramic coated, or even just powder coated with an aluminum color? Then paint the fins to match. Faux aluminum radiator!
Bob
Old 04-01-2010, 10:32 AM   #12
menace121978
i like that... is that welded fitting for the steam vent? i need a link now
"Dennis the Menace"
Old 04-01-2010, 10:38 AM   #13
glock35ipsc
LOL, that was just some random pic I pulled off the intrawebs. But since you mentioned it, you could have an 1/8NPT threaded bung welded in to the back side, down low, so it would be well hidden.
Don't forget too that you can always drill and tap the top of the water pump and run it there. Less hose to run = cleaner looking, since that's what you are shooting for, less clutter.
Bob
Old 04-01-2010, 01:01 PM   #14
rcrahn
rcrahn's Avatar
Might take a look at a double pass or cross flow aluminum radiator such as PN 555-52039 from JEGS. $230.
Does not have steam vent or trans cooling capability. Drill/tap WP for vent as suggested and run seperate trans cooler. For trans could use finned tubular style about $80 or go with small radiator style unit with fan, cost about $150, mounted almost anywhere. I've seen them even mounted on bottom side of bed.
rcrahn is offline   Reply With Quote
Old 04-01-2010, 01:17 PM   #15
87chevy.com
the new replacement radiators from GM for our trucks are no longer copper, theyre the plastic/aluminum.
clint
Old 04-01-2010, 09:13 PM   #16
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
The cooler has to be opposite the hoses. The tank has a divider in it to force the coolant to go across the radiator, otherwise it would just got straight from one hose to the other. Jay
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 04-01-2010, 09:41 PM   #17
menace121978
thanks Jay! i just learned that! i'm going to have to route the cooler lines across the core support some how. i found a really nice radiator with efans, inlet/outlet pass side, tranny cooler, and steam line vent for a great price. http://cgi.ebay.com/ebaymotors/ws/eB...TQ:MOTORS:1123
"Dennis the Menace"
Old 04-01-2010, 10:53 PM   #18
menace121978
now i just need to figure if its better for the tranny lines on the passengerside or the inlet on pass side!?!?!?!!
"Dennis the Menace"
Old 04-02-2010, 11:08 AM   #19
piecesparts
Parts and more parts
piecesparts's Avatar
Get in touch with "Be Cool" and they will make you what you want or they may even have one already. http://www.becool.com/
They set me up with a radiator and fans for my 68 that I am putting a Gen III motor into.
Frank
piecesparts is offline   Reply With Quote
Old 04-02-2010, 11:18 AM   #20
nlped
nlped's Avatar
^^^I think Dennis already pulled the trigger on the Ebay fan. Looks like a good piece. Let us know what you think after you receive it.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 04-02-2010, 06:48 PM   #21
menace121978
i did! for a third of the price of the be cool. i'll def. let everyone know how i like it and how well it does its job!
"Dennis the Menace"
