03-31-2010, 11:53 PM | #1 |
Removal of drip rails
Has any one removed the drip rails from their trucks. I was looking at mine over the doors and above the windshield and wondering if it could be done. Would this compromise the integrity of the roof. If it has been done how did you do it.
Thanks from sunny Tucson ZZZ |
03-31-2010, 11:55 PM | #2 |
Re: Removal of drip rails
I have seen it done a few times. Grinder or a plasma cutter then a grinder. They have no support purpose simply to reroute water.
You doing a full shave? |
03-31-2010, 11:59 PM | #3 |
Full shave, I would like to, I think it will look better, what other options are there.
04-01-2010, 12:04 AM | #4 |
that was what i wanted to do with my project but decided not to. (Wife talked me out of it) Was going to do the front rear bumper delete, cowl fill, gas tank delete, drip rail, pinch points under the cab, and shave the tail gate and mirrors, door handles.
04-01-2010, 12:09 AM | #5 |
I believe there is an article on drip rail removal in a sport truck magazine. Try a search. It seems easy enough after you have instructions. But it does take some time. One thing to remember is in the front you will retain a ridge/ledge that is very obvious. Im sure there are a few build threads that have done it.
04-01-2010, 12:45 AM | #6 |
VA72C10
Just cut about 6-10" at a time, tack weld that section, move on, then after it's all tacked together fill in between the tacks with more tack welds making sure to move along the length of it and not stay in one spot so the heat can stay down.
Looking for a 67-72 swb or blazer project in or around VA. |
04-01-2010, 12:48 AM | #7 |
VA72C10
Here's my cab
04-01-2010, 12:53 AM | #8 |
VA72C10
Personally I like the ledge left at the front because it keeps the body line accross the top of the door but there have been others that have smoothed them completely...
04-01-2010, 01:32 AM | #9 |
after the initial cutting and welding:
during body work: finished |
04-01-2010, 01:35 AM | #10 |
Big Red - Now its a SWB!
I've heard that its not too hard, its just time consuming. Like stated above work in small sections to keep the heat down. There are multiple layers of metal and you just grind it down in small sections then tack it up. good luck and post up some pics to show all us how it goes.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
04-01-2010, 03:26 AM | #11 |
The major issue is how the doors fit aferward its alot of work to get perfect
70 SWB STEPSIDE 70 BLAZER 09 challenger |
04-01-2010, 10:50 AM | #12 |
VA72C10Personally I like the ledge left at the front because it keeps the body line across the top of the door but there have been others that have smoothed them completely...
VA, I know this is off our subject but what the name of the yellow paint on your truck. My truck is going to be yellow also. |
04-01-2010, 10:54 AM | #13 |
Ackattack, VERY nice, I like the stance and the look.
04-01-2010, 11:09 AM | #14 |
Im going to get me a cab and go crazy on removing the drip rail and finishing the firewall and non needed items. I also like the rear cab finish piece scotts makes... I want a totally clean sano cab done!
VA 72c10 your cab looks GREAT!!! and Ack attack PERFECT looking! |
04-01-2010, 12:17 PM | #15 |
VA72C10
Sorry, should have clarified better....the yellow cab is from project Lemon drop that LFD did with Juggernot on here. I think Lemon drop is the name of the color but here is the build thread. I was showing a cab with the front drip rail roofline completely changed like Ackattack did on his
http://67-72chevytrucks.com/vboard/s...ght=lemon+drop
